Proving the Integrability of a Given Function f on Interval [0,1]
  • Thread starter Thread starter roam
    Functions
14 replies · 2K views
roam
I need some help with this question please. Thanks. ::biggrin:
a) Let f: [0,1] [tex]\rightarrow R[/tex] be given by
http://img148.imageshack.us/img148/5435/10187431tc4.gif
Argue that f is integerable.
The attempt at a solution
I don't get it. A function is integerable if its integral exists. How can we integrate this? There is no actual function given here...
So how are we supposed to argue that it is integerable?
What is the derivative of the following function?
[tex]g(x)= \left\{ \begin{array}{rl} 2x & x<1 \\ 3x & x=1 \end{array}[/tex]
edit- on the interval [0,1]
I don't think this problem is about antiderivatives. It's about the definition of the integral in terms of Riemann sums. roam, it is a function. It just doesn't happen to be continuous. That doesn't mean it's not integrable. What's the area under the curve?
Hi dick!
Uh, isn't it [tex]\int_{0}^{1}g(x) dx[/tex]?
Hi! Sure it is, but what's the value of that? Think about Riemann upper sums and lower sums. You have to deal with the definition of the integral. If f(x)=2 the area is 2. Does moving only the single point at x=1 to f(1)=3 change that?
My Idea was to simply show that on the interval [0,1],
[tex]\frac{dg}{dx}=f(x)[/tex]
[tex]\Rightarrow \int_a^b f(x) dx= \int_a^b \frac{dg}{dx} dx =g(b)-g(a)[/tex]
for [tex](a,b) \epsilon [0,1][/tex] showing that the integral clearly exists and hence that f is integrable.
But g(x) isn't differentiable at x=1, it's not even continuous. It doesn't make sense to say dg/dx=f at x=1. There are more basic definitions of an integral existing than that. Besides g(1)-g(0)=3. That's just plain silly. The area under the curve f(x) between 0 and 1 is 2.
Good point, my mistake.
Yes, functions that are not continuous can be integrable.
But Dick I'm not quite sure, we haven't studied some of that yet.
Btw, which definitions do I need to use for proving that f is integrable?
[tex]\sum_{k=0}^{1}k[/tex] [tex]\int_{0}^{1}f(x)dx = F(1)-F(0)[/tex] ?
Roam
You haven't studied Riemann sums yet? Qualitatively, the idea is just that over ALMOST ALL of the interval the function is just f(x)=2. The bit where it jumps up to 3 only makes an 'infinitely small' (whatever that means) contribution to the area. If you don't have a rigorous definition of an integral (not antiderivatives - that's a theorem, not a definition), then you'll have to wave your hands and say stuff like that.
This function has two values i.e.,
f(x) = 2 for all values of x below 1, so this value is integrable
The second value is
f(x) = 3 for x equal to 1, as there is only one number and not a range therefore this can not be integrated and it will have only one value.
thus the original function is integrable.
Does that make sense?
I would recommend partitioning [0, 1] into n intervals with the last interval starting at 1- 1/n, ending of course at x= 1 so it has base length 1-(1- 1/n)= 1/n. You can take the maximum height of that interval to be 3 (the value of f at the right end point) so the maximum area is 3(1/n) which goes to 0 as n goes to infinity. The minimum height would be 2, the function value at the right end point (or anywhere else in the interval except x= 1) so the minimum area is 3(1/n) which also goes to 0 as n goes to infinity. Any other value for the height must lie between 2 and 3 and the area also goes to 0. That is sufficient to show that "f(x)= 3 for x= 1" contributes nothing to the integral. Use whatever method you like to show that f(x)= 2, for x between 0 and 2, is integrable.
The second value is
Sort of. You can integrate f(x)=3 from x=1 to x=1. The result is zero. What I really wanted was a DEFINITION of what an integral is. Nothing in the book or notes??
F is called an integral of f on interval I if F'(x) = f(x) for all x[tex]\in[/tex]I
Then that leaves you in a pretty tough spot. The integrals F(x) of f(x) on the interval [0,1) (not including 1) are 2x+C for any constant. If you define F(1)=2+C then F'(1)=2 not 3. If you define it to be anything else then F doesn't have a derivative since it's not even continuous. Frustrating, huh? I think you are just stuck with arguing the area under the curve should be 2.
