Can this be decrypted using a simple ASCII conversion?
  • Thread starter Thread starter Tech2025
    Encryption Random
The discussion revolves around decrypting a challenging text file, with participants suggesting methods to approach the problem. One key suggestion is to convert the text to hex or decimal to identify patterns, which may reveal insights into its encryption. There is speculation that the encryption might be simpler than initially thought, potentially involving basic encoding techniques rather than complex pseudo-random encryption. The text's length is noted as a factor in the effectiveness of the encoding scheme, and participants recommend using tools that can display the digital representation of the text, such as HEX editors on Linux or MacOSX. The conversation also references the Cicada 3301 mystery, hinting at its possible connection to the challenge at hand.
Tech2025
Hi, I am trying to decrypt something in a .txt file as a challenge from a friend, the file contains:
pÿd“ÙÃÊÌßéh'rv‹"^÷ù O˜w؉D•ÍúúYíY’ ∞¶iÀªÆzI¥r=«Å∑F¸¡„;≥ûü¸ã7∂.ˆ– ã<¿µD~’ÅsG›îwA_4Gå#›¥’6ª˝_ÎaÍÑjù]ÚU3Y{äF-Ê#i 33(›öR `?™|¸ ®flîè+zÂ√œ/fiãìR˛˙˚∂ZëìÆºΩÒ†»˘∂®∑‘¬z vóR◊r∂Øûp)E ·°vÅQ’»<Ø^ÃH‘xïÄ=∂Ë\⁄oYh◊¥h$f)
I think it is Pseudo Random encryption? Can someone give hints on how to decrypt this?
Technology news on Phys.org
No I don't. People try the tricks of the trade to solve these things. One thing is that the message must be long enough relative to the encoding scheme.
If you have access to Linux or MacOSX or an editor that can display HEX you could use that to look at the digital representation.
Likes Tech2025
That's very true, and that text is very short. My guess is that it is a trivial trick, much simpler than pseudo random encryption.
For example, the text looks like the 16 bit UNICODE, what happens if you display the same binary sequence as 8 bit ASCII?
Likes jedishrfu
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
