bjAndrea
- 2
- TL;DR
- This is not my subject, but I need to know if I can convert 10 PSI to energy. for example, If I have a permanent magnet motor rotate X time (RPM) to produce 10 PSI. Now Can I invert this process, if I have 10 PSI and let it pass on a permanent magnet motor, How much electricity will produce? in other words, the source of power is 10 PSI, anyone has the calculation, how much electric coil I need, size of the coil and the length, number of rotation per coil. etc. or just the output how much Amp
This is not my subject, but I need to know if I can convert 10 PSI to energy. for example, If I have a permanent magnet motor rotate X time (RPM) to produce 10 PSI. Now Can I invert this process, if I have 10 PSI and let it pass on a permanent magnet motor, How much electricity will produce? in other words, the source of power is 10 PSI, anyone has the calculation, how much electric coil I need, size of the coil and the length, number of rotation per coil. etc. or just the output how much Amp can produce by 10 PSI pressure, with a pipe of x size.
moreover, if I have 10 PSI continues pressure, I need to convert it to Amp. Anyone can help.
Regards
Regards
