Pulleys with Torque: Free Body Diagram Analysis
  • Thread starter Thread starter rashida564
    Pulleys Torque
34 replies · 5K views
rashida564
In the diagram to the left, a mass m1 is connected through a fixed pulley to a second movable pulley attached to a mass m2, with a massless wire terminating at the ceiling. The two pulleys are identical, have mass M and radius T,and have moment of inertia 1/2MR^2 for rotation about their axes
1)Sketch free-body diagrams for this arrangement
2)What is m1/m2 when the two blocks are in equilibrium?
3)Write down the four equations describing the motion of the blocks. Hence, find an expression for the acceleration of the blocks in terms of the parameters of the problem and g.
F=ma
t=I(alpha)
Free body diagram is below, but I have confusion about the tension. The tension on the block and pulley should always be the same by Newton third law. so T1=T1' and T2=T2'.
Part B) The system is in equilibrium so net torque on each pulley is equal to zero. Therefore T1'=T2' and T2'=T3.
Applying Newton second law of motion 2T1'=m2g and T2'=m1g. So m1/m2=1/2.
Part C) Haven't attempted yet but I think a2 should be half of a1, then there's simultaneous equations to solve it
But my confusion is about T1 and T1'.
Your diagram makes it very difficult for us (and probably you) to understand. I suppose we could figure it out from the text, but why not draw one diagram of the whole system so the relationships are clear?
I hope this one is clearer
Also, your free body diagrams have several errors that are causing confusion. Don’t forget the pulleys have mass, and also where is the connection between mass 2 and pulley 2?
I am thinking of not including the mass since I will only write the torque equation for the pulley
I see nothing in the problem statement to suggest the mass of the pulleys can be ignored. It could be a reasonable approximation for light pulleys. However here they explicitly tell you they have mass. Besides, if they were light you could ignore the rotational inertia too, and that clearly isn’t the intention.
Thx I will have another go in it
So I added the weight of the pulley in the diagram. And wrote the force equations. Where small t net torque. and anticlockwise is the positive direction.
for the pulley in the left t=(T1'-T2)R=1/2MR^2α1. Or T1'-T2=1/2Ma1
torque equation for the right pulley R(T2'-T3)=1/2MR^2α2. T2-T3=1/2Ma2
Force equation For block 1 m1g-T1=m1a
For equation for the system of Block 2 + Pulley " Ignoring the internal forces"
m2g+Mg-T2+T3=m2a
You said, “for the pulley in the left
t=(T1'-T2)R=1/2MR^2α1. Or T1'-T2=1/2Ma1”
When relating the angular acceleration to the linear acceleration, why did both R’s disappear?
One R Cancelled from the one in the left hand side and the other because α =a/R
You said, “For equation for the system of Block 2 + Pulley " Ignoring the internal forces"
m2g+Mg-T2+T3=m2a”
Why is only the mass m2 accelerating?
Sorry I forgot to include the other mass
IS the other equation correct, I have the confusion about the direction of positive and negative with forces and torques
This made me stop solving the question and assuming that my solution is wrong 😢😢😢. It's taken from a past exam in my uni
Oops! My bad. Sorry!
Oh no! You shouldn’t be discouraged. You have it. Your equations in post 9 are well constructed and show a good understanding of how to do the problem. If you left off a mass in one equation or didn’t draw one of the forces on pulley 2 in your force diagrams, that is only a little bit of attention to detail from perfect. Yes, as you mention in post 14 you now have to relate the signs correctly among the 4 equations, but that’s really the last step in setting up the problem.
Regarding relating the equations, what quantity connects them? What do they all share?
  • Love
I assume post #16 is in response to my post #15.
All the equation contains 4 unknown with four equations, that relates the forces (after simplifying the torques equation) with the acceleration. Also I make the connected the acceleration of the a1 and a2 by the constrain equation. But I am scared of the negative and positive torque and how to define the positive direction
This can be tricky. There are formal methods involving right hand rules and vector products, but it’s generally easier just to apply a little thought.
You don't need to guess correctly in advance which way things will move; just choose a positive direction for each force, torque and acceleration and be consistent. To connect forces with torques, is it clear to you that an upward force about an axis to the left leads to an anticlockwise torque?
For pulley problems like this, there is a cheat method. But I won't go into that if you can handle the method above.
Please post your equations.
will the angular acceleration of both pulley be the same since they are connected by a rope
I asked my friend he told me both of them should have the same acceleration be the angular acceleration is tangential acceleration divided by the radius. Both of them have the same tangential acceleration "otherwise the rope will extend" and they have the same radius. So they will have the same angular acceleration
So I alpha is a/R is where a is the acceleration of each pulley
So far I got 4 equations of motions.
First for force assume up to be the positive direction
Constrain equation
a1=2a2
T1-m1g=m1a1=2m1a2
T2+T3-(M+m2)g=m2a2
For the torque equation, I assumed that counter clock wise is positive and also assumed that m1 goes down.
T1R-T2R=1/2 M R^2 (a2/R)(2). Since a1=2a2
so T1-T2=a2M
-T2R+T3R=1/2 MR^2 (-a2/R)
T2-T3=Ma2/2
for part b) I putted a=0 So
T1-m1g=0
T2+T3-(M+m2)g=0
T1-T2=0
2T2-2T3=0
So T2=T3 for the last equation
Then T2=T1 for the third equation
So after that T1=mg from the first equation therefor T2=T3=T1=m1g
From the second equation
2m1g=M+m2
so m1=(M+m2)/2
Which kinda make sense, since the mechanical advantage is 2.
Now what's left is part c.
