Punctured Pipeline: Estimate Oil Release Rate
  • Thread starter Thread starter kolis
7 replies · 3K views
kolis
Hi,
I've got punctured pressurized pipeline transporting an oil. Diameter of pipeline is 50 mm and diameter of the hole is only 2 mm. Pressure in the pipeline is 20 bar and pressure outside is atmospherical. The rate of transported oil is 2m3 per hour and I need to estimate released volume of oil, while pump is still working so I have two flows: one through the hole and another one continuous in pipeline after the hole.
Any help will be appreciated. Thanks
kolis said:
Hi,
Welcome to the PF.
Is this question for schoolwork?
No it's not schoolwork.it has happened and I would like to know how much oil has leaked out.
Ok. But I've still got a problem with understanding this: When I've got a hole in a pipe there are two flows (one trough a hole and 2nd in pipe), so the flow through the hole is just a fraction of incoming flow. In equation it should be Qin=Qhole + Qpipe after hole and when I calculate flow through an orifice its just one flow so Qin=Qorifice
Or am I wrong?
Yes, flow through orifice is a fraction of total flow in. Let's say the flow out the orifice is 2 GPM which equates to 0.45 cubic meters per hour. If you have a flow of only 2.00 cubic meters per hour before the orifice, you only have a flow of 1.55 cubic meters after the orifice.
Ok.
I've found another equation to estimate leakage amount through small holes in a pipeline. It says:
Q=0.61A(2gh)^0.5
where
Q is flow in cu. ft./second
A is cross sectional area, sq. ft.
g is gravitational constant, ft/sec^2
h is head, feet
It looks like this is the right equation for me. Problem is, I don't know what is head or how can I calculate. Any help?
