Eclair_de_XII
- Messages
- 1,085
- Reaction score
- 92
"A block is projected up a frictionless inclined plane with initial speed v0 = 3.5 m/s. The angle of incline is Φ = 32°. (a) How far up the plane does the block go? (b) How long does it take to get there? (c) What is its speed when it gets back to the bottom?"
##v=v_0+at##
Answer as given by book: (a) 1.18 m; (b) 0.674 s; (c) 3.5 m/s
##\vec v_0=(2.97i+1.85j)\frac{m}{s}##
Now, I figure there's downward acceleration from the normal force and gravity. I set the mass of the block (which originally was not specified) to 1 kg, to simplify my calculations.
##F_N=(sin238°)(1kg)(9.8\frac{m}{s^2})=-8.31N##
##F_g=(cos238°)(1kg)(9.8\frac{m}{s^2})=-5.19N##
So, given this, I find the acceleration for a mass that I invented for the block.
##\vec a = (-8.31i-5.19j)\frac{m}{s^2}##
Then I reduce the initial velocity to zero to find the time, which does not correspond with the answer given by the book.
##-1.85\frac{m}{s}=-9.8\frac{m}{s^2}t##
##t=0.189 s##
As you can see, this number does not match up with the answer as given by the book. Also, I just realized that it should be 32 degrees, and not 36 degrees in the FBD I drew on Paint.
