Pushing a Lawnmower: Find tanθ_critical
  • Thread starter Thread starter phthiriasis
2 replies · 15K views · last reply
phthiriasis
Consider a lawnmower of weight w which can slide across a horizontal surface with a coefficient of friction [tex]\mu[/tex]. In this problem the lawnmower is pushed using a massless handle, which makes an angle theta with the horizontal. Assume that [tex]F_{h}[/tex], the force exerted by the handle, is parallel to the handle.
Take the positive x direction to be to the right and the positive y direction to be upward.
http://img408.imageshack.us/img408/2788/mfscf8ayr4.jpg
http://g.imageshack.us/img408/mfscf8ayr4.jpg/1/
A:
Find the magnitude, [tex]F_{h}[/tex] of the force required to slide the lawnmower over the ground at constant speed by pushing the handle.
B:
The solution for [tex]F_{h}[/tex] has a singularity (that is, becomes infinitely large) at a certain angle [tex]\theta_{critical}[/tex]. For any angle [tex]\theta[/tex] > [tex]\theta_{critical}[/tex], the expression for [tex]F_{h}[/tex] will be negative. However, a negative applied force [tex]F_{h}[/tex] would reverse the direction of friction acting on the lawnmower, and thus this is not a physically acceptable solution. In fact, the increased normal force at these large angles makes the force of friction too large to move the lawnmower at all.
Find an expression for tan[tex]\theta_{critical}[/tex]
2. The attempt at a solution
okay, so i got part A fine:
fnet=0
x:
-cos[tex]\theta[/tex]*[tex]F_{h}[/tex]+[tex]F_{f}[/tex]
y:
n-sin[tex]\theta[/tex]*[tex]F_{h}[/tex]-w
multiply the y equation by [tex]\mu[/tex] to eliminate n
-cos[tex]\theta[/tex]*[tex]F_{h}[/tex]+[tex]\mu[/tex]n=[tex]\mu[/tex]n-sin[tex]\theta[/tex][tex]F_{h}[/tex][tex]\mu[/tex]
rearrange to get fh...
[tex]F_{h}[/tex]= (-[tex]\mu[/tex]w)/(-cos[tex]\theta[/tex]+sin[tex]\theta[/tex][tex]\mu[/tex])
part b i just not sure where to start..the force becomes infinite when the denominator becomes 0... but i don't know how to express that in terms of tan[tex]\theta_{critical}[/tex].
thanks for any help
lol i see now someone had the exact same question.. no answer though..here
Welcome to PF!
Hi phthiriasis! Welcome to PF! :smile:
(have a theta: θ and a mu: µ :smile:)
Yes, you're right …
the force becomes infinite when the denominator becomes 0 …
ie cosθcritical = µsinθcritical …
so tanθcritical = … ? :smile:
