How do we properly set and get instance variables in a class?
  • Thread starter Thread starter mathmari
    Class Python
The discussion revolves around creating a Python class named Student, which includes attributes for first name, last name, and email, along with methods to set and get an ID number and department. The initialization of the class is confirmed to be correct, but there are placeholders (using "pass") in the methods that need to be filled out for full functionality. The set/get methods are emphasized as a best practice for managing class attributes, allowing for controlled access and modification of the data. The conversation also touches on the need for additional attributes like ID number and department, suggesting that these can be set later using the defined methods. Overall, the importance of adhering to conventions in object-oriented programming is highlighted, particularly in the context of managing class properties effectively.
mathmari
MHB
Hey! :giggle:
Construct a class named Student which when initializing its objects has the following variables :
- first_name (string)
- last_name (string)
- email (string)
The class should also support the following functions implemented as functions (methods):
- set_id_number: set a registration number (string)
- set_email: set an email (string)
- set_dept: set the department to which the student belongs
- get_id_number: returns the student registration number
- get_email: returns the student's email
- get_dept: returns the department to which the student belongs I have done the following :
Code:
class Student :
    def __init__(self, first_name, last_name, email):
        self.first_name = first_name
        self.last_name = last_name
        self.email = email
    def set_id_number(self) :
    def set_email(self, email) :
        self.email = email
    def set_dept(self) :
    def get_id_number(self) :
    def get_email(self) :
        print ("The email of the student is : " self.email)
    def get_dept(self) :
Is the initialization correct?
Are the methods set and get email correct?
How do construct the methods for id and department? Which information do we use for that?
:unsure:
Technology news on Phys.org
Hi, the init stuff is correct. Your code won't run without adding "pass" to the blank methods. That's a good way of writing placeholders until you write it out in full. This is based on your code and will test an example instance of the class.
Code:
class Student :
        self.email = email
    def set_id_number(self):
        pass
        self.email = email
    def set_dept(self):
        pass
    def get_id_number(self):
        pass
        pass
    def get_dept(self):
        pass
student = Student("John", "Doe", "johndoe@gmail.com")
How could you test if set_email() is working? Try it on the student object above.
We write :
Code:
student.set_email(student.email)
and respectively also for the other methods, right? :unsure:So do we let inside the methods "pass" or do we write a code to do the specific task? :unsure:
"pass" just let's this be valid syntax. Try running the code without it and it should break. It's a placeholder until you write the actual methods. pass = "do nothing but still exist".
Here's how you can set the email using the method you wrote.
Code:
print(student.email)
student.email = "NEWjohndoe@yahoo.com"
Code:
I see!
But for example set_id_number do we maybe count the students and give them the correspinding number as anid? Or how can we set an id? And what about set_dept ? We don't have any information about the department before, how canwe set that then? :unsure:
Ok thinking about this a little more it looks like they want to have a set/get pattern for various attributes. I think this is an example of what they are looking for.
Code:
class Student :
        self.email = email
    def set_id_number(self, id_number):
        self.id_number = id_number
        return self.id_number
        pass
        pass
    def set_dept(self):
        pass
    def get_dept(self):
        pass
student.set_id_number(12345)
print(student.get_id_number())
What would this look like for others?
Code:
class Student :
        self.email = email
        pass
        pass
    def set_dept(self):
        pass
    def get_dept(self):
        pass
Ah I got it! So we write :
Code:
class Student :
        self.email = email
        self.email = email
        return self.email
    def set_dept(self, dept):
        self.dept = dept
    def get_dept(self):
        return self.dept
student.set_email("newjohndoe@gmail.com")
print(student.get_email())
student.set_dept("Mathematics")
print(student.get_dept())
Is that correct ? :unsure:
Constrructing an object of the class means to set and get the information as we did in the main part of the code? :unsure:
That looks good! There are a couple of topics here:
  • In the __init__ method, these are parameters that must be supplied to initialize the class object. So whatever you put here must be given when the class instance (student) is created.
  • The set/get methods are kind of conventions instead of just setting these properties like this:
    • student.email = "newjohndoe@gmail.com"
This would both set this property and retrieve it, but it's bad practice for reasons I can't quite remember and using a set/get pair is considered best practice.​
  • When you have properties not part of the __init___ method you use the get/set methods to work with them so you have the syntax Class.set_property(property) like student.set_id_number(12345)
So you mean that the methods that set an information that we have already in the class is just to alter the given information and if we set a new information it is that we give this for the speciic instant, right? :unsure:
Class instance variables can be set when class is initialized or later on. If required when initialized it will be part of the __init__ method. id_number is an example of an instance variable that isn't set during initialization though.
The way we set/get these variables is separated into two methods by convention. There are some more complex reasons why I think, but for now I would just file this info away as good practice.
  • · Replies 43 ·
11K
  • · Replies 23 ·
