Q(x)=0 special case self-adjoint eqtns
  • Topic:
  • Thread starter Thread starter ognik
4 replies · 2K views · last reply
ognik
For the special case $\lambda=0, q(x)=0 $, the self-adjoint (SA) eqtn becomes $\displaystyle\d{}{x} \left[p(x) \d{u(x)}{x}\right]=0$, satisfied by $du/dx=1/p(x) $. Use this to get a 'second' solution of (a) Legendre's eqtn (b) Laguerre's (c) Hermite's. Note, in all 3 cases, $u_1(x)=1$
Not sure why $du/dx=1/p(x) $ automatically produces the 2nd solution?
I don't know where they got $u_1(x)=1$ from for all 3 eqtn types?
(a) With p(x)=$(1-x^2)$, I got $ u(x)=\frac{1}{2} (ln\frac{(1+x)}{(1-x)}- ln(1)) $ integrating between 0 and x, is this INTERVAL correct?
(b) They provide a solution of $ u_2 (x) - u_2(x_0)=\int_{x_0}^{x} \frac{e^{t}}{t} \,dt $. With p(x)=$xe^{-x}$, I got the same integral, but would like to know why they wrote this solution (only this one) as $ u_2 (x) - u_2(x_0)=...$? And why they used $x_0$ instead of 0 for the interval? And why you think they the answer as an integral, when they completed the integration for (a)?
If you plug in for what $p(x)$ is for each of the three cases, you will get a solution that is not equal to $u_1=1$. So the word "second" is relative to the "first solution" $u_1=1$.
If you plug in $u_1=1$ into the DE as a candidate solution, its derivative is zero, so when you multiply that by $p$ and differentiate again, you get zero as you should.
Do you need an interval?
To emphasize that it's a displacement? I'm not entirely sure without looking at the context.
To allow for nonzero initial conditions, presumably.
Because that integral isn't do-able, at least not in terms of elementary antiderivatives. You can write it as the "exponential integral", but it has no elementary antiderivative.
If you plug in $u_1 =1$ into the DE as a candidate solution, its derivative is zero, so when you multiply that by p and differentiate again, you get zero as you should.
Granted, but in general, how should I know to try $u_1 =1$ if they hadn't told me?
This covers the rest of my questions.
It's a self adjoint eqtn., so I thought it must have boundary conditions? Also an indefinite integral would leave me with an unknown constant in the solution. Finally the book has definite integrals in the other 2 given solutions. (Me, I sometimes find intervals limiting...)
Interestingly the intervals they use don't correspond to the orthogonality intervals.
Partial reply here:
Intuition, recognizing patterns, experience, imagination. In general, if I see a somewhat complicated-looking DE, or even a not-so-complicated-looking DE, I'm going to see if the trivial solution solves it, which you can usually check by inspection. Then I'm going to see if a constant solves it: again, you can usually check by inspection since all the derivatives will vanish.
Ackbach said:
Partial reply here:
Yay, nice I hadn't missed something
More interested in understanding the second part ... I think I need intervals as per my attempted justification?
