Understanding Gluon Self-Interaction and Quark/Gluon Jet Differentiation
The forum discussion centers on the experimental evidence for gluon self-interaction, specifically the existence of three and four gluon vertices as predicted by Quantum Chromodynamics (QCD). The DORIS experiment at DESY and the TASSO experiment are highlighted as key contributors to the discovery of gluons through three-jet events. However, while these experiments confirm gluon existence, they do not provide definitive evidence for the three and four gluon vertices. The OPAL experiment at LEP is mentioned as having observed a decay signature involving four jets, which may relate to three gluon vertices, but the existence of four gluon vertices remains theoretically inferred rather than experimentally verified.
  • Understanding of Quantum Chromodynamics (QCD)
  • Familiarity with particle physics experiments, specifically DORIS and TASSO
  • Knowledge of Feynman diagrams and their significance in particle interactions
  • Basic concepts of jet differentiation in high-energy physics
  • Research the OPAL experiment at LEP and its findings on four-jet events
  • Study the paper on jet differentiation algorithms referenced in the discussion
  • Explore the implications of SU(3) symmetry in QCD and its experimental signatures
  • Investigate the statistical methods used to analyze coupling strengths in particle interactions
Particle physicists, researchers in high-energy physics, and students studying Quantum Chromodynamics and jet differentiation techniques will benefit from this discussion.
Malamala
Hello! Based on QCD we can have gluon self-interaction i.e. a vertex with 3 or 4 gluons. What were the experimental evidences by which the existence of these vertices was confirmed? Also, how does one differentiate between a quark and a gluon induced jet? Thank you!
You mean TASSO, right?
vanhees71 said:
Usually the three-jet events discovered at the end of the 1970ies by the DORIS experiment at DESY are taken as the discovery of gluons:
https://www.wikiwand.com/en/Gluon#/Experimental_observations
Thank you for the reply. I will read the references in more details, but I am not sure I see how does this prove experimental evidence for the 3 and 4 gluon vertex. Based on the Feynman diagrams there, we either have some sort of bremsstrahlung, where one of the quarks produce a gluon (and hence we have 2 jets produced by quarks and 1 by a gluon) or the decay of that Y resonance producing 3 gluons, but the gluons don't come from a 3 gluon vertex, but from 3 quark-quark-gluon vertices. That is clear evidence for the existence of gluons, but I don't think it is evidence for the fact that the symmetry of QCD is SU(3) i.e. at the time it was expected that we need a boson to mediate the strong force, but it wasn't clear that the symmetry group of that interaction is SU(3) (which predicts 3 and 4 gluon vertices). As far as I can tell the references that you mentioned prove the existence of the gluon. I was actually more interested if there was an experiment with a clear signature of 3 and 4 gluon vertices, and how they figured that out?
Also, how about my second question, how do they differentiate between 3 jets produced by 3 gluons and 3 jets produced by 2 quarks and a gluon i.e. what is the experimental difference between a quark and a gluon jet? Thank you!
Vertices are not real things. The four-gluon vertex is not gauge invariant by itself and it may not even be finite. The real things are amplitudes, or at least event rates.
Thank you for your reply. I am not sure what you mean. Vertices are very real. When you have 2 quarks produced from a gluon, it is a vertex with a clear experimental signature (2 jets). I just came across the attached picture which partly answer one of my questions: they used that decay signature i.e. 4 jets to confirm the existence of 3 gluon vertices (this is from OPAL experiment at LEP). I am not sure what you mean by "not real", but that vertex seems very real and it has a clear experimental signature (i.e. 4 jets). This still doesn't answer my 4 vertex question, too. Based on this picture, I would imagine you could have 3 gluons coming from the original one (hence 4 gluon vertices) and 5 jets in the final state? Was this observed? If not, do we know experimentally, in any way, that the 4 vertices exists (or it is just inferred theoretically), in the same way we know about 3 vertices (i.e. a clear experimental signature)? And if so, could you point me towards that specific experiment?
I'm not going to argue with you.
You don't need to argue... If you explain to me clearly why that 3 gluon vertex there is not real I would understand probably. You just stated that vertices are not real, that is not an explanation... Or you can just give me a link to some experiments proving what I am asking for...
In general, there are some differences between quark and gluon initiated jets. There are algorithms that use those differences to identify such jets. Just from a fast search I came across this paper, and for example you can see some diferentiating variables in Fig. 1:
https://arxiv.org/abs/1712.03634
The general way I've seen people approaching parameters in diagrams (e.g. the coupling strengths), is by trying to determine them statistically. I.e. you can assume that the strength is 0 (so the vertex doesn't exist) and compare your expectations with data that consists with jets in your final state. You would probably see that you also need the additional diagram to get a better description, and then by a fit you determine its value.
One extra thing is that you never access diagrams, they are a way to "encode" mathematical expressions. The only thing you have access to is the amplitudes that arise from adding the diagrams and taking their magnitudes squared.
You basically "never" see a photon decaying to electron positron, you see a photon, a Z and their interference decaying into this lepton pair.
  • · Replies 35 ·
9K
