QFT Index Question Homework: Solving Euler-Lagrange Equations w/ F_{mu,nu}
  • Thread starter Thread starter spacelike
    Index Qft
The discussion focuses on solving the Euler-Lagrange equations for a Lagrangian involving the field strength tensor F_{μν}. The main query is whether to treat A_{μ} and A_{ν} as separate fields or as a single entity when differentiating in the Euler-Lagrange equation. The user initially attempted to change both indices, resulting in delta functions, but seeks confirmation on the correctness of this approach. Concerns about maintaining proper index notation and covariance requirements are emphasized, along with issues encountered in LaTeX formatting. The user expresses a desire for clarity on the technique used in their solution.
spacelike
I'm learning QFT and trying to do a basic problem finding the equations of motion from the Euler-Lagrange equation given a lagrangian.
The lagrangian is in terms of:
F_{\mu\nu}=\partial_{\mu}A_{\nu}-\partial_{\nu}A_{\mu}
so then my issue comes in with this part of the Euler-Lagrange equation:
\frac{\partial\mathcal{L}}{\partial (\partial_{\mu}\phi)}
Now, I'm not sure if I am supposed to treat this as two separate fields or not. My first attempt to solve this I made a change of index from \mu\rightarrow\lambda and \nu\rightarrow\gamma in the Euler-Lagrange equation so that I got terms that look something similar to:
(there's more terms and factors but I'm just showing the relevant part)
\frac{\partial (\partial_{\mu}A_{\nu})}{\partial (\partial_{\lambda}A_{\gamma})}-\frac{\partial (\partial_{\nu}A_{\mu})}{\partial (\partial_{\lambda}A_{\gamma})}
This then results in delta functions which multiply the other factors in the equations and I get the final answer.
OR
Am I supposed to only change ONE index and treat A_{\mu} and A_{\nu} as separate fields, so that I would only do \mu\rightarrow\lambda (again, only for the euler-lagrange equation)
and get two equations with terms similar to:
\frac{\partial (\partial_{\mu}A_{\nu})}{\partial (\partial_{\lambda}A_{\mu})}-\frac{\partial (\partial_{\nu}A_{\mu})}{\partial (\partial_{\lambda}A_{\mu})}
\frac{\partial (\partial_{\mu}A_{\nu})}{\partial (\partial_{\lambda}A_{\nu})}-\frac{\partial (\partial_{\nu}A_{\mu})}{\partial (\partial_{\lambda}A_{\nu})}
NOTE: I did it the first way and the answer looks reasonable to me, but I just want to make sure my technique was correct.
You should never have the same index in the differentiations, you need to adapt all indices so that the equations respect the correct covariance requirement
\left[\partial_{\mu}\left(\frac{\partial_{\sigma}A_{\lambda}-\partial_{\lambda}A_{\sigma}}{\partial\left(\partial_{\mu}A_{\nu}\right)}\right)\right] F^{\sigma\lambda}
So you can see that:
* the free index is \nu
* "fractions" corresponding to differentiations do not mix indices
* no index appears more than twice, twice iff summed over.
There's something wrong with the LaTex code...Hmmmmm...
\left[\partial_{\mu} \left(\frac{\partial_{\sigma}A_{\lambda}-\partial_{\lambda}A_{\sigma}}{\partial \left(\partial_{\mu}A_{\nu}\right)}\right)\right] F^{\sigma\lambda}
:smile:
:smile:
I missed an operator.
\left[\partial_{\mu} \left(\frac{\partial\left(\partial_{\sigma}A_{\lambda}-\partial_{\lambda}A_{\sigma}\right)}{\partial \left(\partial_{\mu}A_{\nu}\right)}\right)\right] F^{\sigma\lambda}
Now the \lambda is not correctly parsed...
\left[\partial_{\mu} \left(\frac{\partial \left( \partial_{\sigma}A_{\lambda} -\partial_{\lambda}A_{\sigma}\right)}{\partial \left(\partial_{\mu}A_{\nu}\right)}\right)\right] F^{\sigma\lambda}
Problem seems to be that the bb software is fond of inserting spaces in inappropriate places in order to break up long space-less lines.
  • · Replies 18 ·
  • · Replies 30 ·
