QFT: Scattering Amplitudes in Yukawa Theory
The discussion focuses on the Yukawa theory, specifically analyzing the tree-level scattering amplitude for the process e-ϕ → e+ϕ. The interaction term is given by gϕ&overline;ψ&psi, as described in Srednicki's QFT book, chapter 45. Participants conclude that the amplitude is zero because valid Feynman diagrams cannot be constructed without violating charge conservation, which is enforced at the diagram level. The inability to create consistent diagrams indicates that the process does not contribute to the amplitude.
  • Understanding of Yukawa theory and its interaction terms
  • Familiarity with Feynman diagrams and rules
  • Knowledge of charge conservation in quantum field theory
  • Proficiency in using Srednicki's QFT textbook
  • Study the construction of Feynman diagrams in Yukawa theory
  • Learn about charge conservation principles in quantum field theory
  • Review examples of tree-level scattering amplitudes in QFT
  • Examine the implications of non-existent diagrams on scattering processes
Quantum field theorists, students of particle physics, and researchers analyzing scattering processes in Yukawa theory will benefit from this discussion.
Sonny Liston
I'm working with the Yukawa theory, where the interaction term in the Lagrangian density is g\varphi\overline{\psi}\psi. As an exercise for getting used to using the Feynman rules for the theory, I'm asked to show explicitly (i.e. I'm not allowed to invoke charge conservation) that, at tree level, the amplitude for the process e^-\varphi \rightarrow e^+\varphi is zero.
The interaction is g\varphi\overline{\psi}\psi. Just set notation, we're using Srednicki's QFT book and the discussion of Feynman rules for the Yukawa theory is chapter 45.
This process yields two diagrams at tree level. My first though was that I would write down the diagrams and they would cancel in some nice way, but I'm actually stuck even trying to write down sensible diagrams for this process; writing down diagrams that are in accord with the Feynman rules while also yielding things that look like amplitudes is proving difficult. In particular, there are no barred spinors in the resultant amplitudes; the incoming electron and outgoing positron both contribute unbarred spinors. Is there a way to write down diagrams for this process that make sense? If so, am I on the right track in expecting that they would cancel, or have I totally misunderstood how to go about this?
Can you describe the diagrams you've found that describe this process? Are you sure you have all of your arrowheads going in the correct directions?
I think I've got my arrows right. I tried to type out the diagrams themselves, but couldn't get it to work so I'll just describe them.
Starting from the left:
Diagram 1: incoming electron, momentum P, with an arrow to the right flowing toward the first vertex. A scalar line with momentum K flowing into the first vertex, and an internal fermion propagator with momentum (P+K) flowing out of the vertex (arrow to the right). The second vertex has a scalar line with momentum K' flowing out of the vertex, and an outgoing positron, with momentum P'. This has an arrow facing to the left, flowing into the second vertex.
Diagram 2: The same as diagram 1, except the order of the scalar lines is swapped: the first vertex now has a scalar line with momentum K' flowing out of the vertex, yielding an internal propagator with momentum (P-K'), while the second vertex has a scalar line with momentum K flowing into the vertex.
Does that sound right, or have I done something stupid with the arrows for the outgoing positron?
Well, that's the right direction of arrow for the outgoing positron, but that means you have two arrows flowing into the second vertex, correct? If so, those don't correspond to valid Feynman rules--the rules say that every vertex in Yukawa theory has one arrow flowing in and one flowing out. This is the way that conservation of charge is enforced at the diagram level--it shouldn't be possible for you to make a diagram that violates charge conservation if you follow the rules correctly.
Right, that's part of what I was trying to get at (and expressing poorly) when I said I was having trouble writing down diagrams that made sense. Following the rules for electron/positron arrows produces a diagram that violates the rule concerning arrows flowing into and out of vertices.
So I guess that's my question: does "showing explicitly" that the tree level amplitude is zero just mean showing that you can't write down diagrams for the process that are consistent with all the Feynman rules? Or when you say "it shouldn't be possible for you to make a diagram that violates charge conservation if you follow the rules correctly", do you mean I've not been careful enough somewhere in writing down the diagrams?
It's an oddly-worded question, so I guess I'm not sure, but if it were me, that's probably what I would go with. I'm not really sure what else you can do with it--charge conservation in QFT holds diagram-by-diagram, so you're not going to find even one single diagram that violates it. That means there aren't any calculations to do, so I'm not sure how you can "show it explicitly" in any way other than to say that the sum of all relevant diagrams is trivially 0.
That was my original thought -- you just couldn't write down sensible diagrams for the process. The wording was what then got me all tangled up thinking diagrams should cancel and whatnot.
Thanks for all your help!
  • · Replies 134 ·
11K
