QT Programming with Debian or Ubuntu Linux - a problem
5 replies · 10K views
Pollywoggy
I am running Kubuntu Hardy Heron and I have the same problem I had with Debian, that the Qt packages put the libs and includes all over the place, not in one place such as /usr/lib and /usr/include
This means that I can't set QTDIR unless I obtain the Qt sources and compile and install in /usr/local/qt but that is a waste of disk space.
Is there a way to get source code requiring Qt to compile without having to install a second Qt?
This sounds strange. Firstly, no, you don't need to compile Qt from source in order to install the libraries. Synaptic should have a list of the Qt packages - make sure you install the dev packages as well.
As far as I can recall, Hardy places Qt in /usr/share/qt4 (there are also Qt3 libraries in /usr/share/qt3, but presumably you're working with the latest Qt and don't need these). You don't say precisely what it is that you need to know $QTDIR for, but I'll assume you're trying to compile some sources that rely on the Qt libraries. Have you tried passing
Code:
./configure --with-qtdir=/usr/share/qt4
prior to building? There are symlinks in that directory that tell the compiler that the Qt libraries and includes are in /usr/share/lib and /usr/share/include.
Alternatively, you could always just set $QTDIR to the above in your .bashrc.
Code:
It's not a problem when I am compiling source code that comes with a configure script, the script knows where to find the libs and includes. It is a problem when I try to compile code from a tutorial or book.
I am going to try your suggestion of setting QTDIR to /usr/share/qt4
thanks
I think I am on the right track now and all the compile errors have to do with KDE and not Qt.
This means I need to do for KDE something along the lines of what I did for Qt, following the ideas you gave.
thanks
Solved
thanks
I set KDEDIR to /usr/lib/kde4 and this did the trick. I will put that in my ~/.bashrc and the QTDIR as well and also add the $QTDIR/bin and $KDEDIR/bin to my PATH.
