Quadratic equation of two variables
11 replies · 3K views · last reply
LagrangeEuler
Quadratic equation
[tex]Ax^2+Bxy+Cy^2+Dx+Ey+F=0[/tex]
is
(a) elipse when ##B^2-4AC<0##
(b) parabola when ##B^2-4AC=0##
(c) hyperbola when ##B^2-4AC>0##
I found this in Thomas Calculus. However for some values of parameters ##A=17##, ##C=8##, ##B=\sqrt{4 \cdot 17 \cdot 8}##, ##D=E=0##, ##F=20## I got just straight line. Where is mistake?
There is no mistake. That quadratic equation is the general equation of a conic section. (When you intersect a cone with a plane.) So in special cases you can get a line, intersecting two lines or even a single point. A circle is also possible. Just google "conic section", you'll understand what I mean...
Well look my example. In my post for ##A=17##, ##C=8##, ##B=\sqrt{4 \cdot 17 \cdot 8}##, ##D=E=0##, ##F=20## I got just straight line. And for that is ##B^2-4AC=0##, and it is not parabola.
Look at the first wikipedia picture:
243062
and imagine shifting the purple plane to the right until it contains the origin. The 'conic section' is a line in that case
Let me expand Thomas' classification then:
(a) elipse (or circle; or point) when B2−4AC<0
(b) parabola (or line) when B2−4AC=0
(c) hyperbola (or two intersecting lines) when B2−4AC>0
the cases in the paranthesis are called degenerate conic sections. (not sure this nomencleture applies to circle though)
Here is curve for ##A=17##, ##C=8##, ##B=\sqrt{4 \cdot 17 \cdot 8}##, ##F=20##. These are two parallel lines.
  • Plot of two parallel straight lines with positive slope on axes labelled x1 (horizontal, -4 to 4) and x2 (vertical, -4 to 4), with the lines crossing the x2 axis near 1.5 and -1.5.
That's funny -- you sure ? With that choice of parameters the first three terms form a square and those are usually non-negative, not -20
Sorry. My mistake. ##F=-20##. Other parameters, are the same. So equation is
[tex]17x^2+\sqrt{4 \cdot 17 \cdot 8}xy+8y^2=20[/tex]
Sort of like ##x^2 + 2xy +y^2 = 1 ## if I try to keep it simple.
The intersection of ##z^2=(x+y)^2 ## with ##z^2=1## in homogenous coordinates with a determinant 0, leading to one of the degenerate cases
I grant you I have a hard time forming a picture like in #4 ... ( @erbahar ? )
Didn't quite understand the question (I feel like I might have missed the context, sorry)
My initial reply #2 was to give a geometrical answer to the question.
Of course you can always write something like:
##(ax + by + c)^2 = -4##
which is a perfetly legitimate quadratic, however it does have no solution in the real plane. Parallel line example is also of that sort.
eg. ##(ax + by + c)(ax + by + d) = 0##
OP corrected the value of F so the form is ##(ax+by)^2 = ## positive, with two parallel lines. I wondered what picture to form of a plane intersecting a cone in that specific case ...
Oh, I see now. I don't think it's possible to picture that as an intersection.
