Quadratic forms under constraints
6 replies · 2K views · last reply
mr.tea
Member warned about posting with no effort shown
Find the minimum value of ## x_1^2+x_2^2+x_3^2## subject to the constraint:
## q(x_1,x_2,x_3)=7x_1^2+3x_2^2+7x_3^2+2x_1x_2+4x_2x_3=1 ##
I am not really sure how to think about it. I have seen the opposite way but have not seen this type of question yet. Any guidance will be very helpful.
Thank you.
Thank you.
What do you mean by "the opposite way"?
I mean something like "find the max/min of ## q(x_1,x_2,x_3)=7x_1^2+3x_2^2+7x_3^2+2x_1x_2+4x_2x_3## under the constraint ## x_1^2+x_2^2+x_3^2=1##"
I know how to solve this type of questions. This is the opposite way(maybe "way" is not a good word here)
How would you solve the "opposite way" problem? And why does that method not work in the present case?
Because there is a theorem that says that at the unit sphere(## x_1^2+x_2^2+x_3^2=1##) the max/min of the equation is at the max/min of the eigenvalues of the form. I cannot use it here.
Yes, you can.
You can change variables to ##u_i = U_i(x_1,x_2,x_3)## for ##i = 1,2,3##, where the ##U_i## are linear functions of the ##x_j##, devised so that your ##q(x_1,x_2,x_3)## has the form ##u_1^2 + u_2^2 + u_3^2##. Then, if you reverse the transformations to get ##x_i = X_i(u_1,u_2,u_3)##, the functions ##X_i## will be linear in the ##u_j##, and so ##f(x_1,x_2,x_3) = x_1^2 + x_2^2 + x_3^2## will be quadratic in the ##u_j##. That problem will be exactly of the type you can solve already.
However, I don't know why you would ever want to do this; it is much easier to just solve the problem directly using the Lagrange multiplier method.
Ray Vickson said:
Yes, you can.
Thank you for the answer. I am not sure that I got it 100% but I will work on it.
This is a question from a past exam in linear algebra. The subject of Lagrange multiplier is not covered in this course. I am not sure if I want to start talking about the course. I have a lot of bad things to say...
By the way, now I understand the reason why I couldn't find any explanation or notes about something similar to that...
Thank you for the help, I appreciate it!
Thomas
