Quadratic Graph & Bouncing Ball
The discussion revolves around analyzing the motion of a bouncing ball using quadratic equations to determine key parameters such as acceleration, initial velocity, and displacement. The user is attempting to calculate the values of B and C for each bounce, noting that these values may not remain constant due to shifts in the graph. There is confusion regarding the negative values of A and C, as well as the interpretation of the kinetic and potential energy before and after each bounce. The conversation emphasizes the importance of understanding the relationship between potential energy, kinetic energy, and momentum in the context of the ball's motion. The user is encouraged to clarify the discrepancies in their data and calculations to ensure accurate analysis.
tariel
Hi guys. I've been a lurker for a while, but I've recently become super stumped on this physics question (physics is far from my forté). I've attached the graph of my bouncing ball. First, I had to identify the coefficients and what they mean. I understand that A is acceleration, B is initial velocity, and C is displacement.
I understand that the graph is shifting, and B and C of the second bounce are not necessarily equal to those numbers. How do I find the true values of B and C for each subsequent bounce?
This is my graph:
http://i.imgur.com/5pnfJY5.png
Y = Ax^2 + Bx + C
y = y0 + vot + 1/2at^2
For the first bounce, I was able to find the initial height by doing:
Y = Ax^2 + Bx + C, with x = 0.6 seconds
Y = -4.460(0.6)^2 + 5.425(0.6) - 0.7426
Y = 0.9068 m
And velocity:
dy/dx = 2(-4.460)x + 5.425, with x = 0.6 seconds
dy/dx = 0.073 m/s
I believe I need to find these values in order to calculate the kinetic energy before and after impacts, and finding linear momentums - I have to fill out a chart like this one for seven bounces:
I also have no mass for the ball, p is basically equal to the velocity. And I am told that PE must be equal to KE of the ball at the beginning and at the end of each interval of free flight.
y = Ax + Bx2
y = y'
x' = x + δ
∴ x = x' - δ
Rewrite above equation using this relationship between the two variables
So the B value would stay the same?
It seems so yes.
What type of detector did you use to get the data?
I used a motion sensor hooked up to Logger Lite software, can't remember the exact specifics as I did the data collection some time ago.
I just want to make sure I'm doing this right, my tutor hasn't responded to me yet. So for the second bounce, using your equation, this is what I did:
Bounce 1 occurred between 0.2-0.9 seconds.
δ = 0.9 - 0.7 = 0.2
x = x' - δ
= 0.9 - 0.7
x = 0.2
Bounce 2:
y = Ax^2 + Bx
= -4.320(0.2)^2 + 12.36(0.2)
= 2.29 m ? Should this not be lower than the first bounce? (and why am I not incorporating C?)
Then
dy/dx = 2(-4.320)x + 12.36
= 2(-4.320)(0.2) + 12.36
= 10.632 m/s
I don't have a clue if I'm going about this correctly!
So the ball was bouncing up and down while the motion sensor was looking down onto it?
This means that you have time on the x-axis and distance from the motion sensor on the y?
What are the units for each?
If the variables on the axes are y(t) then one would expect a relationship of the form:
y = yo - vot + 1/2 gt2
which does not agree with the fitted coefficients - the signs are wrong. So maybe the motion sensor's measurements was used to calculate the ball's distance from the floor. In this case one would expect
y = yo + vot - 1/2 gt2
in which case the signs of the fitted coefficients agree, but still the meaning of C0 worries me.
Sorry, I'll go back to the beginning. I have a feeling this is simpler than what it seems, but my tutor has yet to respond to me.
Yes, the sensor was held vertically above the bouncing ball. The data collected produced this graph:
http://i.imgur.com/QSxyot1.png
y-axis is the vertical distance between the ball and the sensor, x-axis is time.
This graph was analyzed using Graphical Analysis, the y-axis was altered so it would show the ball's position relative to the ground instead of the sensor.
I did quadratic fits for each bounce interval on the new graph, which I posted earlier but I'll post it again:
http://i.imgur.com/xme9ZBP.png
After that, these were my instructions:
"Fitting the data points corresponding to each interval, using the equation Y = A t⋀2 + B t + C (see Fig 5.3). Write a clear interpretation of the meaning of each parameter in this equation.
I said that A represents acceleration, B represents initial velocity, and C represents initial position.
From the fit results of each interval, you should notice that the B parameter increases as the ball makes a new bounce! If B is interpreted as the initial velocity of the ball for the corresponding bounce, this seems to contradict the observed loss of mechanical energy after each bounce! Can you explain this apparent discrepancy?
I'm guessing it's due to the shift, but I'm not understanding these values. I don't understand why A and C are negative, why C is becoming increasingly negative, as well as what is going on with the velocity. I'm not sure how to account for these in the analysis either. The example they gave produced a graph similar to mine, with similar patterns in how the A, B, and C values increase/decrease.
And THEN I have to do this:
Using the maximum height of the ball, it should be possible to calculate its maximum potential energy (PE) in the middle of each interval. From the principle of conservation of mechanical energy, this must be equal to the kinetic energy (KE) of the ball at the beginning and at the end of each interval of free flight. Therefore, you should be able to calculate the kinetic energy per unit mass (KE/m) just before and just after each impact with the ground. The momentum per unit mass (p/m) can also be calculated just before and just after each impact. Note that this quantity is basically equal to the ball’s velocity.
After showing detailed sample calculations, construct a table similar to the one shown below, in which you include the changes in the kinetic energy and momentum as a result of each impact. Note that the momentum is a vector quantity, and therefore, the sign is very important.
And this is where I'm trying to get the velocities... unless I don't have to and just use the B values. But I'm getting numbers that do not make sense to me.
If you mean the time shift, yes. Consider the second bounce as if it were just the top part of a single trajectory that started at time 0, i.e. about one second before any of its datapoints. Where would the trajectory have started at time 0, and with what speed?
For A, what is the cause of the acceleration? Which way does that act? Which way are you measuring Y?
For C, see my comment above on time shift.
You can't use the B values for the reasons given: they do not represent velocities all at the same height.
I knew it was simpler than what I was doing!
Okay, so since I have max. heights for each of the bounces, I can find PE as g*h. So before impact, KE = PE. After impact, KE would be the PE of the following bounce, correct?
And since momentum is the velocity in this case (no mass was recorded), it would be:
1/2 mv^2 = mgh
v = sqrt 2*g*h
Am I correct in my thinking here?
1/2 mv^2 = mgh
v = sqrt 2*g*h
Yes, that's all correct. Btw, in the graphs, something odd seems to have happened between the third and fourth bounces. It looks like the sensor got knocked down a bit.
Probably me! I was holding it above while simultaneously trying to make the ball bounce directly below. I'll just take note of the discrepancy in the write up, since it's basically saying the ball gained energy somehow, haha.
