How Much Water Sheds from Mediterranean to Adriatic Sea?
  • Thread starter Thread starter _medo88_
    Homework
The discussion centers on calculating the volume of water that sheds from the Mediterranean Sea to the Adriatic Sea, specifically focusing on the negligible height of tide at the entry point. The height of tide in Tržaški zaliv is noted as 60 cm. A participant calculated the volume using the formula for the area of a triangle, resulting in 37 Tl, based on dimensions of 783.3 km in length and 157.4 km in width. The calculation method and the resulting volume were confirmed as appropriate for the homework assignment.
  • Understanding of basic geometry, specifically the area of a triangle
  • Familiarity with tide measurements and their implications on water volume
  • Knowledge of geographic dimensions relevant to the Mediterranean and Adriatic Seas
  • Ability to perform unit conversions, particularly for volume measurements
  • Research the geographic area of the Adriatic Sea for more accurate calculations
  • Learn about tidal effects on coastal water bodies
  • Explore advanced volume calculation methods for irregular shapes
  • Investigate the significance of water volume in environmental studies
Students studying physics, particularly those focusing on fluid dynamics and environmental science, as well as educators looking for practical examples of tide calculations.
_medo88_
I'm new on this forum, so I hope I picked the right thread.
For my Physics, I heve to do a homework.
Because the height of tide at entry of Mediterranean to Adriatic sea is negligible, assess from this and geographic data, how much amount of water sheds from Mediterranean to Adriatic sea.
height of tide in Tržaški zaliv=60cm
I'm apologising myself for mistakes I made in text.
TNX
Welcome to PF!
Hi medo88! Welcome to PF! :smile:
First, you need to find the area of the Adriatic sea.
Then draw a diagram for yourself … show the surface of the water at low tide and at high tide (or does the question only want half of this?) … what shape do you think that surface should be? :smile:
Yes, I was thinking that if this is a shape of triangle?? But, I'm not shure if that is right.
It's probably much more complicated than a triangle …
but I think that is what the homework wants you to use.
So what is the volume? :smile:
Ok, tnx.
I just asked, because I wasn't sure, it looked to easy.
I calculated and the result was 37 Tl , what do you think??:confused:
Hi medo88! :smile:
I've no idea … you have to show me your calculations! :smile:
l...length=783,3 km
w...width=157.4 km
t...difference between low and high tide=60 cm
(l*w*t)/2=37Tl
Yes that looks like the right formula! :smile:
hmm … I agree with the 37, but not the Tl.
How do you get that?
  • · Replies 16 ·
  • · Replies 17 ·
