Quantum 1D box obtain an expression for the normalization constant
The discussion focuses on obtaining the normalization constant for an electron in a one-dimensional box, defined by the wave function ψ. The normalization constant A is determined to be A = (a)^(-1/2) through the normalization condition. For the lowest energy measurement, participants clarify that the Hamiltonian operator must be applied to the wave function to find the eigenvalues, indicating that the first non-zero coefficient corresponds to the second state (n = 2), as the ground state yields zero due to symmetry considerations.
  • Understanding of quantum mechanics principles, particularly wave functions and normalization.
  • Familiarity with Hermitian operators and their role in quantum measurements.
  • Knowledge of the Hamiltonian operator and its application in quantum systems.
  • Basic concepts of eigenvalues and eigenstates in quantum mechanics.
  • Study the derivation of normalization constants in quantum mechanics.
  • Learn about the application of the Hamiltonian operator in quantum systems.
  • Explore the significance of eigenvalues and eigenstates in quantum measurements.
  • Investigate the properties of wave functions in one-dimensional potential wells.
Students and educators in quantum mechanics, physicists working with quantum systems, and anyone seeking to deepen their understanding of wave functions and energy measurements in quantum mechanics.
mike232
An electron in a one-dimensional box with walls at x =(o,a) is in the quantum state
psi = A o<x<a/2
psi = -A a/2<x<a
A) obtain an expression for the normalization constant, A.
B) What is the lowest energy of the electron that will be measured in this state?
Not given anything. But its a chapter on Hermitian operators, and Hamiltonian.
So for part a I think I am just supposed to normalize, so 1=integral of A*A ... and I get A=(a)^(-1/2) which i think is my normalization constant.
But is it asking not for the constant but to work back and find an equation?
For part b,,, I just operated on psi with the Hamiltonian and because all I had were constants, I got zero... which is boring if true, but I think isn't the answer I am looking for.
If anyone could help out, many thanks.
It is only asking for A, in order to normalize the wave function, such that you can do part B.
That is indeed not the correct approach. What you have to do is decode what
actually means. What possible results can you get if you measure the energy of the electron?
DrClaude said:
It is only asking for A, in order to normalize the wave function, such that you can do part B.That is indeed not the correct approach. What you have to do is decode what
Don't you find the energy by using the Hamiltonian operator? If this isn't I have no idea what to do with this.
What do the postulates of QM say about measurements?
The only measurable results are the eigenvalues associated with the operator... but I don't know how that helps because zero is a valid result.
Yes, and given the wave function, what is the probability of finding a given eigenvalue?
Do I find the expansion coefficent?
Yes. You basically need to calculate the coefficients, starting from the ground state and going up in energy, to find the first one that is not 0. Then you can get the lowest possible measured energy.
So
OK so I haven't done the work yet. But just intuition it's something like the second state?
Good intuition. The ground state is even with respect to the center of the box, while ψ is odd, so the integral will be zero. You should get a non-zero coefficient with the first excited state (n = 2).
  • · Replies 24 ·
  • · Replies 0 ·
