How to Show Inner Products in Quantum Mechanics Using Fourier Transforms?
The discussion focuses on demonstrating the equivalence of inner products in quantum mechanics using Fourier transforms. Specifically, it establishes that the inner product (\psi_1, \psi_2) can be expressed in terms of momentum space representations, leading to the equation (\psi_1, \psi_2) = \int dk \phi_1^*(k) \phi_2(k). The use of the delta function, \delta(k_1-k_2), is crucial for simplifying the integrals and performing the necessary substitutions. The final result confirms that the inner product can be computed directly in momentum space.
  • Understanding of inner products in quantum mechanics
  • Familiarity with Fourier transforms and their properties
  • Knowledge of delta functions and their applications in integrals
  • Basic concepts of wave functions in position and momentum space
  • Study the properties of the delta function in the context of Fourier transforms
  • Learn about the implications of momentum space representations in quantum mechanics
  • Explore the mathematical foundations of Fourier transforms in quantum theory
  • Investigate the role of inner products in quantum state orthogonality and normalization
Students and professionals in quantum mechanics, physicists working with wave functions, and anyone interested in the mathematical techniques used in quantum theory.
v_pino
Given (\psi_1, \psi_2)=\int dx \psi_1^*(x) \psi_2(x), show (\psi_1, \psi_2)=\int dk \phi_1^*(k) \phi_2(k), where \phi_{1,2}(k)= \int dx \psi_k^*(x) \psi_{1,2}(x) and psi_k(x)=\frac{1}{\sqrt{2 \pi}} e^{ikx}.
\psi (x)= \int dk \phi(k) \psi_k(x)
\psi(x)=\int dk \phi(k) \psi_k(x)
(\psi_1 , \psi_2)= \int dx \left \{ \int dk \phi_1^*(k) \psi_k^*(x) \right \}\left \{ \int dk \phi_2(k) \psi_k(x) \right \}
=\int dx \left \{ \int dk \phi_1^*(k) \frac{1}{\sqrt {2 \pi}}e^{-ikx} \int dk \phi_2(k) \frac{1}{\sqrt {2 \pi}}e^{ikx} \right \}
= \frac{1}{2 \pi}\int dx \left \{ \int dk \phi_1^*(k) \int dk \phi_2(k) \right \}
Is this correct so far? How do I proceed from here? It looks like a Fourier Transform with the 1/2pi. And I have two integrals within another one for the dx. Can I separate them some how?
When you substitute in the integrals for \psi_1^*(x) and \psi_2(x), the k in one integral isn't the same variable as the k in the other integral. If you use the same variable for both, you're almost certainly going to confuse yourself. In this case, you can't cancel out the e^{-ikx} factor from one integral with e^{ikx} from the other.
=\int dx \left \{ \int dk_1 \phi_1^*(k_1) \frac{1}{\sqrt {2 \pi}}e^{-ik_1x} \int dk_2 \phi_2(k_2) \frac{1}{\sqrt {2 \pi}}e^{ik_2x} \right \}
I have revised my equation above. But now that the exponents don't cancel, how should I proceed with this?
You want to use the fact that \delta(k_1-k_2) = \frac{1}{2\pi}\int_{-\infty}^\infty e^{i(k_1-k_2)x}\,dx
(\psi_1, \psi_2)=\delta(k_2-k_1) \int dk_1 \phi_1^*(k_1) \int dk_2 \phi_2(k_2)
Is the delta function equal to 1 in this case? And has the equation given in the problem (\psi_1, \psi_2)=\int dk \phi_1^*(k) \phi_2(k) combined k_1 and k_2?
The delta function depends on k1 and k2. You can't just pull it out front like that.
By using the delta function, you can perform one of the integrations. I suggest you read about the delta function to see how that works.
I obtained (\psi_1, \psi_2)=\int dk_2 \phi_2(k_2) \int dk_1 \phi_1^*(k_1) \delta(k_2-k_1) = \int dk_2 \phi_2(k_2) \phi_1^* (k_2) by using \psi(x)= \int dx' \psi(x') \delta(x-x')
Is it correct? Thanks for the help once again.
Yes, that's correct.
