Quantum mechanics interpretation matching my own view
  • Context: Undergrad
  • Thread starter Thread starter bhobba
    Interesting Qm
276 replies · 21K views
A. Neumaier said:
No - you take the state to be a hidden variable that each particle carries.
But according to the statistical interpretation of QM, the state is not assigned to a single particle but only to an ensemble of identically prepared particles.
Of course, I take the state to be the only hidden variable. That means you do not introduce anything foreign into the theory and you can apply the LC concept to the theory without changing or perturbing it.
There are no particles carrying anything or state assigned to anything. There are only two predictions made according to the laws of quantum physics that notoriously fail to pass the test. It is a laconic mathematical expression that ordinary QM does not pass.
A. Neumaier said:
You still lack proof that your LC can be applied to QM. Where is the precise theory-independent definition of LC that contradicts QM?
facenian said:
Equations (7) and (8) in this paper https://arxiv.org/abs/2102.07524
Why are these two equations a precise theory-independent definition of LC?
I see neither an encoding of local nor one of causality. (7) is just a denial of the independence of ##a## and ##b## given ##\lambda##, which is obvious when you set ##a=b## - even classically.
facenian said:
In fact, there is a problem here with regards to the EPR paper. EPR introduced a metaphysical concept, i.e., "elements of physical reality". This has produced much unnecessary confusion to this day.
I don't see what is confusing about "elements of physical reality". It's a placeholder for some unknown physical property. It can be a field magnitude or a particle property or who knows what. The argument is clear and simple, unlike Bohr's response to it.
The mistake of EPR was to insist on the simultaneous existence of non-commuting properties. This is not necessary. You measure both particles on Z and you conclude that those measurements must be predetermined (hidden variables) or that one measurement determines the other (non-locality). Why bother with the X or Y spin at all? EPR's choice to introduce counterfactuals allowed Bohr to attack the argument.
A. Neumaier said:
Correlations at different points in space are nonlocal, by definition, because they depend on what happens at both points. No matter how you try to explain them.
OK, then a chess table is a non-local object according to your definition. Such "non-locality" is of no concern since it does not contradict relativity. The type of non-locality which is forced upon us by the EPR argument (if hidden variables are denied) does contradict relativity because you need to postulate a causal link between space-like measurements. Let's call this relevant type of nonlocality FTLC (faster then light causality).
A. Neumaier said:
I discuss locality in Section 4.4-4.5 of Part II of my preprint series, and in Chapter 13.5-13.6 of my book.
I red those chapters but I admit I do not understand what is your explanation for the perfect EPR anti correlations (I think it's better to only discuss the case of measurements performed on the same axis, say Z and not bother with rotating detectors).
You say:
"The thermal interpretation explicitly acknowledges that all quantum objects (systems and subsystems) have an uncertain, not sharply definable (and sometimes extremely extended) position, hence are intrinsically nonlocal.
Thus it violates the assumptions of Bell’s theorem and its variations."
I do not think this is true. A pair of rotating billiard balls or a long rod are extended objects, "intrinsically nonlocal" - according to your definition of locality - but you cannot violate Bell's inequalities with them. At no point does Bell assume that the entangled system must consist of a single point in space which seems the only object you would call "local".
"Attempting to literally interpret the two photons in a system with an entangled 2-photon state leads
to paradoxes related to seemingly acausal nonlocal correlations."
As pointed out earlier, the EPR argument makes no assumption regarding the nature of those photons, fields, or whatever they might be. It only looks at the properly recorded measurement results.
"Whatever Alice and Bob measure far away depends on the whole 2-photon system."
So, this extended 2-photon system is a hidden variable?
"Over long distances, the uncertainty intrinsic to the 2-photon system becomes huge"
And how is this supposed to help us? Being more uncertain does not seem to help achieving the perfect predictions possible in the EPR situation. And, again, why is this relevant?
"The object becomes vastly extended – so nonlocal that the assumptions in Bell’s argument are obviously violated."
No, not any large object can pass Bell's theorem.
"Alice’s and Bob’s position are causally unrelated."
Agreed, this is what relativity implies.
"But something else from Alice becomes known to Bob faster than light – conditional information."
This is another way of saying that EPR correlations are known to exist. We know that.
"In Bell-type experiments, the conditional information and the correlations become actual only when someone (like Charles) has access to the actual data resolving the condition"
True, but irrelevant.
"It is easily seen that extended causality is observed."
This is an assertion. It does not follow from anything you said before.
You conclude:
"This doesn”t explain everything about the observed correlations"
It doesn't explain anything. If your "extended object" determine the measurement results you have a hidden-variable theory and is consistent with relativity. If your "extended object" doesn't determine the results then it must behave like a perfectly rigid object which is impossible in relativity. Which is it?
Maybe it doesn't follow from what he said before, but it is seen easily nevertheless. The real issue is that "extended causality" is weaker than what QFT actually provides. And A. Neumaier both knows this, and also acknowledges this:
Eberhard & Ross [13] gives a proof of causality from relativistic quantum field theory, in the sense that no faster than light communication is possible.
This doesn”t explain everything about the observed correlations but casts some doubt on the validity of the stringent assumptions made in derivations of Bell-type inequalites.
So you complain: "It doesn't explain anything." Well, it only removes the paradox, but the analysis how it occurs still needs to be done. A. Neumaier acknowledges this by writting:
With the thermal interpretation, the measurement problem turns from a philosophical riddle into a scientific problem in the domain of quantum statistical mechanics, namely how the quantum dynamics correlates macroscopic readings from an instrument with properties of the state of a measured microscopic system. This problem will be discussed in Part III [39].
He defines extended causality like that:
"Joint properties of an extended object depend only on the union of the closed past cones of their constituent parts, and can influence only the union of the closed future cones of their constituent parts."
OK, so how the "Joint properties" of the 2-photon relate to the observed measurement outcomes? If they strictly determine the outcomes we are in the case of a hidden variable theory. If not, the 2-photon behaves as perfectly rigid rod, violating relativity. Since Neumaier explicitly agreed that space-like events cannot cause each other he should say that what he proposes is a hidden variable approach. However, he claims:
"The thermal interpretation gives a natural, realistic meaning to the standard formalism of quantum mechanics and quantum field theory in a single world, without introducing additional hidden variables."
The measurement problem was not the subject of our discussion. The EPR correlations were the subject, and he does not explain them. This is why I said he explains nothing. He says that the 2-photon is a fuzzy/uncertain extended object, itself obeying extended causality. OK, great. So now what? What does this object has to do with the observed correlations? We will see in part III. I've just searched part III for EPR and got nothing.
The "joint properties" of the 2-photon alone don't strictly determine the outcomes. The state of the world on the other hand does strictly determine the outcome. And since you we will never exactly know the state of the world, that state could be regarded as a sort of hidden variable. But in any case, it is not a hidden local variable theory, so Bell's theorem doesn't apply.
However, what is meant by "the state of the world"?
• is description-dependent but observer-independent, hence free from subjective elements;
• is about both real systems and idealized systems, at every level of idealization;
So it is not "subjective", but still description-dependent. And it could be about an idealized system, instead of the real world. Since all our models (as long as they don't include quantum gravity) are idealized, "the state of the world" will basically always be about an idealized system. And since it is not "subjective", it is not what we know or want to assert about the state, but the mathematical state itself (which could potentially contain an infinite amount of information).
Since "the state of the world" in the thermal interpretation is basically the quantum mechanical state, the problem is less to explain the correlations, but to explain why we observe definite measurement outcomes. And that is the measurement problem.
It is not confusing as a well-defined concept, it is metaphysical and produces confusion. An example of this confusion is the belief that the Bell inequality requires such a hypothesis for its derivation. Another confusion is that determinism implies it. Determinism only means you can predict a result with certainty it does not have to assume its pre-existence, however, EPR assumes the pre-existence by definition. It is not "incorrect"; it is unnecessary and metaphysical because makes an assumption about the existence of what has not been actually measured.
Einstein with his keen insight immediately reacted to this since he did not write the paper.
Unfortunately, the concept is widespread and widely used except perhaps by experts in foundations.
They are precise because the definition is cast unambiguously in mathematical form. They are theory-independent regarding QM and local hidden variables because they are applicable to both theories independently.
The fact that to obtain QM we have to put [itex]\lambda=|\psi\rangle[/itex] should not be a problem for any student with certain training in abstract reasoning. It means that the expression is general enough to encompass both theories. When the only information is the quantum state and the probabilities are given by the Born rule or the projection postulate we have ordinary QM. When the ##\lambda## variables represent more (or different) of what is contained in QM we no longer have QM.
Precisely! That encodes the heart of the local causality concept since ##a## and ##b## are space-like determined having an instant influence. QM notoriously fails to pass this criterion.
You don't like it? Perfect, the solution is to change the definition of what locality should mean.
My claim is: if we want our beloved theory to be local, let us make it local but in a coherent way, not by recoursing to denialism nor by merely declaring it local by decree or even worse: uttering tautologies devoid of any sensible meaning like "QM is local because the Bell theorem is the classical result". That is the message of the referenced paper.
PS: there may be other ways to make QM coherently local but my claim is that just declaring it local by definition is not enough because there are reasonable arguments to consider it as implying nonlocal effects therefore those arguments need counter-arguments to justify the locality.
[Moderator's note: Off topic content deleted.]
This may be a little off topic, but the way I see it is that the issue, problem, or source of confusion is that Einstein was referring to a SINGLE case of a 2-photon system, whereas nearly everyone else is arguing from an ensemble of identically prepared systems. By the way, how do we KNOW each part of the ensemble is IDENTICALLY prepared? Isn’t that just an assumption based on our current level of knowledge of what we think may occur at the leading edge, or center, or exiting edge of an SG device? Or knowledge of (or maybe lack of consideration of) EXACTLY where the individual electron or ion passes a slit in relation to the slit edges or boundaries and how this may possibly affect different parts of the prepared ensemble?
Because we use the same device as a source for the entire ensemble. "Identically prepared" does not mean we know the exact details of each individual particle in the ensemble. It just means, for example, "we prepared a beam of electrons by firing them from a cathode ray tube at such-and-such voltage".
This belief is correct, there is no confusion. Bell clearly states this in his paper:
On the Einstein Podolsky Rosen paradox
https://cds.cern.ch/record/111654/files/vol1p195-200_001.pdf
"THE paradox of Einstein, Podolsky and Rosen [1] was advanced as an argument that quantum mechanics could not be a complete theory but should be supplemented by additional variables. These additional variables were to restore to the theory causality and locality. In this note that idea will be formulated mathematically and shown to be incompatible with the statistical predictions of quantum mechanics."
So, Bell investigates the only theories that could preserve locality (the hidden-variable ones). His theorem is not to be applied on non-hidden variable theories since those have been proven to be non-local by the EPR argument.
In the context of the EPR argument the "elements of reality", the hidden variables must determine the outcomes. Without such deterministic behavior the perfect correlations cannot be guaranteed. So, determinism in regards to those "elements of reality" is a conclusion of the argument. Locality requires deterministic hidden variables. Of course, you can have non-deterministic hidden variables but those cannot do the job, they are useless.
If you can predict something with certainty without disturbing the system, as EPR specified, that something must preexist. If the measurement at A does not disturb the system at B, the state of B (or its lack of state if you are a non-realist) remains unchanged after that measurement. But QM says that after the A measurement B is in a well-defined spin state. So, it logically folows that even prior the A measurement B was in a well-defined spin state, otherwise the A measurement disturbed B. Really, there is no counter to that. The argument is rock-solid.
No, it does not. EPR makes exactly 2 assumptions:
1. The results are always corelated. (this is not even an assumption anymore, it's an experimental fact), and
2. locality (the A measurement does not disturb B)
The pre-existence of the hidden variables are deduced from the above assumptions. It's a conclusion, not a premise.
I agree that EPR made a mistake in including the non-comuting properties in their argument. Such a step was not necessary. The argument works perfectly with only the property that is actually measured. So, if you measure spin UP on Z at A you can deduce that you have spin DOWN on Z at B even before B was measured. There is no point to make any assumptions about the X-spin or Y-spin here.
That means that it contradicts relativity.
OK, any way you put it, the thermal interpretation does not explain the observed results in an EPR experiment. They are somehow determined by the state but we don't know how.
We know this from validating it by measurements. E.g., the preparation of photon pairs in all 4 possible kinds of polarization-Bell states is well established using different kinds of parametric down conversion using birefringent crystals like BBO, and it's well established because the properties of such states predicted by QED are indeed observed with an amazing accuracy.
E.g., one of the seminal papers, which is very well understandable, describing the realization of type-II phase matching
P. G. Kwiat et al, New High-Intensity Source of Polarization-Entangled Photon Pairs, PRL 75, 4337 (1995)
https://doi.org/10.1103/PhysRevLett.75.4337
The thermal interpretation is just an interpretation, not a modified quantum theory. Therefore, the expectation is that it should not contradict relativity more than quantum (field) theory itself. More generally, there is no reason to expect that it will contradict relativity more than the theory/model that you interpret with its help. And in cases where it currently does (for example because it didn't yet work out exactly what to do with Gauge freedom or renormalization), there is little reason to assume that this could not be fixed.
Yes, we don't know exactly how the state determines the results. But we can try to workout which parts of the state have a big impact on the results, and which parts only have an extremely small impact on the results. The task is then to show that neither the most exact precision of the state of the particles themselves, nor the state of some atom in a galaxy lightyears away has a significant impact, but that the state of the measurements devices, and other "local" properties of the state indeed has some impact.
facenian said:
They are precise
But they are not a definition from which one could see how they are related to informal notions of causality and locality. Just dropping some formulas does not give them physical contents.
The extended object is the 2-photon state, That it is not rigid does not matter.
The variables I introduce are the q-expectations. They are nonlocal for a 2-photon state. They are hidden in the sense of Bell's terminology but not in the more standard sense that quantum mechanics would have to be completed, since q-expectations belong to the standard toolkit of quantum mechanics.
I disagree. QM is non-local only if it assumed to be complete (no hidden variables). If one does not make that assumption the theory could be local. So, it's possible that some interpretations conflict with relativity and some other don't. As you specified that the thermal interpretation rejects local hidden variables, it has to be non-local in the sense that space-like events cause each other. This is conflict with relativity.
Are they non-local in the sense that space-like events cause each other?
Indeed, it is possible that some interpretations conflict with relativity and some others don't. What I wrote was a reply to your assertion: "That means that it contradicts relativity."
Also note that an interpretation can have non-local aspects without contradicting relativity. For example, the randomness occurring in the Copenhagen interpretation can be non-local. But this sort of non-locality doesn't necessarily contradict relativity. If the non-locality could be used to enable faster than light communication, then the interpretation would clearly contradict relativity.
I admit that there are other ways to contradict relativity. For example, even pilot wave theory doesn't allow faster than light communication. But it has a preferred frame of reference, and you might feel that this contradicts relativity. Fine with me, but then you should be specific about which parts of an interpretation contradict relativity from your point of view.
Well, space-like events can certainly be correlated with each other. But as long as you cannot clearly distinguish between whether it is event A that causes event B, or event B that causes event A, it remains unclear whether the events A and B really cause each other.
The problem is that relativity does not distinguish between space-like events that enable communication and those that don't. Say you measure 10 spins at A: 0010101011. If those spins were not already at B (no local hidden variables) it means that this particular string was teleported instantly at B. This is an explicit faster than light information transfer.
Given that relativity cannot say if A sent the "signal" 0010101011 and B received it or vice-versa you need to introduce an absolute reference frame, otherwise different accounts would contradict each other. So you are in the same situation as Bohm's theory.
As long as you assume that there are no local hidden variables we know for a fact that A and B cause each other, it's the only logical conclusion.
Of course not. Microcausality is implemented in the very construction of all our relativistic QFT models. So there cannot be causal conncections between space-like separated events.
I also don't understand, why one should call correlation functions with more than one spacetime argument "nonlocal". After all the correlations, described by these correlation functions are observed in local experiments with the "registration events" of the outcome at the spacetime arguments of these functions.
The q-expectations of fields are local, and the n-point functions for ##n>1## are nonlocal because they depend on more than one spacetime argument. Bell experiments require for their analysis the 2-point functions.
For the same reason why the distance to the andromeda nebula is a nonlocal quantity. Anything that depends on more than one spacetime coordinate is necessarily nonlocal.
it is nonrelativistic, hence allows like all nonrelativistic QM instantaneous long distance effect. The probability of a particle prepared in a Gaussian state to be the next moment at Andromeda is nonzero.
No. B cannot extract any information from the correlations.
Well, the physical meaning of a length between 2 points (non-local) and a correlation function, which describes correlations between two or more local (!) measurements is different.
2-point functions are called correlation functions, but in general they do not directly describe measurable correlations. They are just nonlocal mathematical expressions. Only sometimes they can be interpreted in terms of measured correlations.
Independent of this, measured correlations at distinct points are still bilocal since you compute them you need to measure at two points, not only at one.
The distance to Andromeda is not a local quantity, but why would you call it nonlocal! The oposite of local is not always nonlocal, for example it could be global.
