Quantum physics: proving wave packet is normalized
The discussion focuses on proving the normalization of the Gaussian wave packet defined by the function ## \psi (x)= \frac{1}{\sqrt{\sqrt{\pi a^2}}} e^{-\frac{x^2}{2a^2}}##. Participants clarify that the normalization condition requires evaluating the integral ## \int_{- \infty}^{\infty} |\psi (x)|^2 dx = 1##. The solution involves recognizing the Gaussian integral, where ##\int_{-\infty}^{\infty} e^{-x^2} dx = \sqrt{\pi}##, and applying a transformation to polar coordinates for easier computation. The key takeaway is the importance of correctly handling the constants and transformations in the integration process.
  • Understanding of Gaussian wave packets
  • Familiarity with Gaussian integrals
  • Knowledge of polar coordinates in integration
  • Basic calculus, specifically integration techniques
  • Study the properties of Gaussian wave packets in quantum mechanics
  • Learn advanced integration techniques, including polar coordinate transformations
  • Explore the derivation of the Gaussian integral ##\int_{-\infty}^{\infty} e^{-x^2} dx##
  • Investigate the applications of normalization in quantum mechanics
Students of quantum physics, physicists working with wave functions, and anyone interested in mastering integration techniques related to Gaussian functions.
Jillds
Following gaussian wave packet: ## \psi (x)= \frac{1}{\sqrt{\sqrt{\pi a^2}}} e^{-\frac{x^2}{2a^2}}##
Prove that this function is normalized.
Is ## \frac{1}{\sqrt{\sqrt{\pi a^2}}} \int_{- \infty}^{\infty} e^{-\frac{x^2}{a^2}} dx## equal to 1?
I have a solution given, but I don't really get how they even got that solution:
## \frac{1}{\sqrt{\pi a^2}} \sqrt{\pi a^2}## = 1
But that solution totally ignores the double root in the first term, and I'm mond boggled how they managed to integrate the exponent to ending up as ##\sqrt{\pi a^2}##? Actually I don't manage to clearly and unambiuously integrate that exponent myself.
First, note that the equation in 2 has the square of the wave function. That is why the exponent is exp(-x^2 / a^2) instead of exp(-x^2 / [2*a^2] ). Right? So why didn't you square the multiplier out front as well?
As to how to do the integral: The problem is you have this integral of exp(-x^2/a^2) with respect to x. And that's hard. But note that it's an integral from -infinity to +infinity. And the hint is that the answer seems to have a square root in it. So what about doing the square of the integral? You can convert to an integral over r and theta in 2-D, and you should be able to do that integral. Then take the square root, and violins.
You are correct. I forgot to square the constant before the exponent. My eye fell on the fact that it's a Gaussian wave packet, therefore it's a Gaussian integral, which is basically what you're epxlaining (I think). ##\int_{-\infty}^{\infty} e^{-x^2}## would be ## \sqrt{\pi}## and the ##a^2## would just be multiplied under the squareroot following the features of a Gaussion integral. So, yes the solution I had from the course is what I was so puzzled about.
Did you also learn how to actually do this integral $$
\int_{-\infty}^{\infty} e^{-x^2}\ \ {\rm ?} $$
There is mention of it in later chapters, with regards to Dirac and Fourier.
Nah, don't need all that complicated stuff for this one. it's a simple but very nifty trick, good to remember (I did:) ):
They change from the 1D integral to its square, a 2D integral. In polar coordinates the ##dx\; dy## transform to ##r \;dr\; d\phi## and then it's easy (using ##r\;dr = {1\over 2}d(r^2)\ ## ). See Wiki
Thank you very much. Yes, with the polar coordinates it's not that hard. :)
