Quantum scattering theory (lab frame, center of mass frame)
The discussion clarifies the differences between the lab frame and the center of mass frame in quantum mechanics scattering theory. In the center of mass frame, the total momentum of the system is zero, allowing for simpler calculations of particle interactions. Conversely, in the lab frame, one particle's momentum is typically set to zero, making it more applicable for experimental setups. Both frames describe the same physical interaction but offer different conveniences for analysis and prediction.
  • Understanding of quantum mechanics principles
  • Familiarity with momentum conservation laws
  • Knowledge of reference frames in physics
  • Basic grasp of scattering theory
  • Study the implications of momentum conservation in quantum scattering
  • Learn about transformations between different reference frames in physics
  • Explore advanced topics in quantum scattering theory
  • Investigate experimental setups in particle physics using lab frames
Physicists, students of quantum mechanics, and researchers involved in particle physics who seek to understand the practical applications of different reference frames in scattering experiments.
moriheru
Greetings,
Here is my question:
What is the difference between the labframe and the center of mass frame in QM scattering theory? Is it that in the labframe both particles are moving towards each other and in the center of mass frame one particle is static and a second one is moving towards the stationary particle?
Thanks for any clarifications.
The opposite. In the center of mass frame the total momentum of the system vanishes \vec{P}=\vec{p}_1+\vec{p}_2=0. In the lab frame one usually takes one of the two momenta to be zero, say \vec p_2=0 and hence \vec P=\vec p_1.
I see thanks Einji. But why use two frames and not one universal frame, thus translating between frames would be unecessary?
Well, first of all there is no such things as a "universal frame". What would it be? Also, usually the center of mass frame is a much easier environment to work out the calculation but most of the experiment are performed with one of the targets fixed and so you want to "translate" your prediction into the lab frame.
Are the frames just different scenarios of scattering?
No. They are the same scenario - the exact same physical interaction - as it would be described by two different observers. It's generally easier to calculate the energies, momenta, and trajectories of the particles using a frame in which the total momentum is zero. Once we have that, we can transform to the lab frame to see what the collision will look like there.
Thanks Nugatory,but if the scenarios are the same what is the difference between the threads if they describe the same scenario?
moriheru said:
Thanks Nugatory,but if the scenarios are the same what is the difference?
The ease of calculating the outcome. When you do the calculation in the center of mass frame, you know that the total momentum of the collision products must be zero.
So can one use the center of mass frame when the total momentum of the colisionproducts is zero and the labframe when the total momentum of the colisionproducts is nonzero? Thanks Nugatory. Is it due to the conservation of the momentum?
No, you can transform the frame to make the total momentum of the collision products to be zero. For the same reaction, I can describe it in whatever reference frame I like.
I choose the centre of momentum frame to do my calculations in, because it makes them much easier to do, then I may choose to transform to the lab frame when I want to understand what the outcome of the reaction will look like on my detectors.
This thread has helped thanks for all clarifications
  • · Replies 134 ·
11K
