Quantum theory - Nature Paper 18 Sept
183 replies · 26K views · last reply
DarMM said:
Related to the Pusey-Leifer theorem and other recent work in Foundations, assuming no fine tuning they (i.e. Realist interpretations like MWI, Bohmian, Transactional) should also show up in deviations from "regular" QM in the early universe, e.g. CMB or similar.
This is in regards to the lack of operational time symmetry, right? Since I’ve seen you mention this a few times, I wanted to understand it a bit myself. It seems to me P&L are premature in claiming WMI doesn’t have operational time symmetry. In their paper they only seem to consider the complete final state, but in a real experiment you won’t be able to measure that as you’ll only have access to one of the resulting branches.
To look for operational aspects it’s more appropriate to post-select on the result of your measurements. It seems TSVF is an appropriate way to view operational aspects in WMI; the backwards evolving state can be used as an index to which branch you find yourself in. P&L explicitly mention TSVF as satisfying their assumption and since both formalisms make the same predictions for branching observers, they should have equal operational qualities.
The paper Measurement and collapse within the two-state vector formalism (2014) shows “how macroscopic time reversibility is attained, at the level of a single branch of the wavefunction”.
That paper is explicitly not a Many-Worlds theory:
Aharonov said:
It will inherit the advantages of the MWI without assuming multiple realities
It's a retrocausal fine-tuned (as they mention when discussing the future boundary conditions, they just think the tunings are of a reasonable class) model, as one would expect from the Pusey-Leifer theorem.
How can Bohmian QM and MWI be both "realistic". I thought, "realistic", is for a sharp physicists' interpretation synomymous for "deterministic". Then BM is "realistic", while MWI is not, or how do you define "realistic"? I think the word "realistic" is "burnt" in a sense by the philosophers, because everybody seems to have a slightly different definition for its meaning. So one has always to mention which definition one follows.
That's true, but it's a fine distinction. They are assuming the backwards wave function is ontic, but you can also take it as epistemic, in which case it's just a way to analyse a single branch, which is what's relevant for operational concerns. Anyway, my main point is that P&L did not actually analyse MWI and find that it violates operational time symmetry, so their claim is invalid.
You can say it's fine-tuned, but the nature of the fine tuning is what I'm after. In this case, the fine-tuning means "like a classical world".
Realistic is more clear in philosophy, and it means that there is some objective state. Realists believe there is something like that; anti-realists think everything is subjective. The MWI is realistic, because the wave function is real. In Bohmian QM, it's that plus a world-particle, to pick out the world you are in.
I don't think the word "realistic" means anything consistent to physicists.
Also, MWI is deterministic - it has only unitary evolution so that's obvious.
The definition used in Quantum Foundations (which I am using) is essentially the presence of a decorrelating explanation (in the sense of Reichenbach's principle). Less technically it would mean that the quantum probabilities follow in some sense from intrinsic properties of the system (in addition to those of the apparatus possibly).
It's separate to determinism. Bell's theorem (the 1976 version) is ultimately about this sense of realism as opposed to determinism.
I don't like the phrasing either, but it is standard.
Not sure I see that. Why is that electron spin up rather than spin down?
Having one world versus a multiverse of ##\aleph_{1}## cardinality worlds is a fine distinction? It seems almost one of the largest conceivable distinctions possible in my mind. Unless I'm missing something.
Could I have a reference to how this is done. The paper you linked relies on it being ontic as it has physical effects, I don't think one can simply state it can also be taken as epistemic without a proof that all relevant aspects work out the same. As results like the PBR theorem show us, you can't simply say "this can be taken epistemically" without proof when it comes to QM.
To come back to this:
Only an ontic TSVF satisfies their assumption as they state.
MWI explicitly breaks Operational Time Symmetry (OTS) at the global level, one can see that immediately.
You are saying that on restriction to a single branch one gets an "effective backward time state" that is epistemic, that somehow restores OTS in a branch, even though Price's argument shows only an ontic backward state does this. I'd like to see the details as the ontic nature of the backward state is crucial to removing the need to fine-tune to restore OTS.
Genuine question, do you think an ontic wave traveling back in time toward the Big Bang containing precisely classical information (not approximate) distributed exactly in a Born distribution is okay and simply a fine-tuning in a pedantic irrelevant sense?
Finally note that when I say Many-Worlds, I mean only Everett's theory, not multiverse interpretations in general. The "parallel lives" interpretation for example escapes Price and Pusey-Leifer's arguments and is an interpretation with multiple worlds, it's just not a "wave-function and nothing else" multiverse like Everett. Essentially it has additional "charges".
(On a personal note, although I'm not an advocate, I find the parallel lives explanation of how nonlocal correlations don't break locality much more comprehensible than Many-Worlds, whose explanation of things like Aravind-Mermin Pentagram correlations simply seems blatantly nonlocal to me)
In the MWI, it's both: there is one branch where the electron is spin up, and all other systems, including your brain, observe it to be spin up; and there is another branch where the electron is spin down, and all other systems, including your brain, observe it to be spin down. This is what unitary evolution produces from an initial state in which the electron is in a superposition of spin up and spin down and all other systems are in "ready to measure" states.
When it starts in superposition, there is clearly nothing that "determines" it will become spin up. One world will have one, and vice versa. How can we - in our world - claim that could have been determined in advance? It is pure chance, by design! All outcomes occur.
That's correct; unitary evolution does not determine it will be spin up. Unitary evolution determines that it will become entangled with the measuring device, the environment, your brain, etc., so that the states of all of those things are correlated. This evolution is perfectly deterministic; it just doesn't determine that the electron will become spin up. It determines something else.
No MWI advocate claims that it is determined that the electron will be spin up, so you are attacking a straw man here. As I said in my previous post just now, unitary evolution is deterministic, but "deterministic" does not mean "determines that the electron is spin up". It determines something else.
These two sentences contradict each other. The second statement is correct. The first is false; a correct statement would be that it is determined that all outcomes occur. There is no chance in the MWI anywhere. It's all deterministic. It just doesn't determine what you're claiming it determines.
Please bear in mind that I am not saying I think the MWI is correct. I'm just saying that we should be clear about what it actually says.
I think it's a fine distinction because it doesn't have physical effects, so the paper could have been written without the ontic claim. I have read this (quotes below) and I think about it like this: Using just unitary evolution, we assume (or show elsewhere) that approximately classical branches emerge. One of those resulting states can be used as a boundary condition - it's where we actually end up. Then we can use the starting and ending boundaries to show the history between them, just looking at the total contribution from the other branches. It's just pre/post-selection of intermediate states; it doesn't change what those states are.
Time Symmetry and the Many-Worlds Interpretation (2009, Lev Vaidman)
My additional backwards evolving state is not of this kind (at least until I introduce a more speculative modification below). It is an explanatory concept for the inhabitants of a particular world.
The fundamental ontological picture remains, as in standard MWI, that of a single forwards evolving quantum state. The forwards evolving state of measuring devices defines the outcomes of measurements which, in turn, define the forwards and backwards evolving states within a world.​
The Two-State Vector Formalism (2013, Lev Vaidman)
The TSVF is equivalent to the standard quantum mechanics, but it is more convenient for analyzing the pre-and post-selected systems and allowed to see numerous surprising quantum effects. The TSVF is compatible with almost all interpretations of quantum mechanics but it fits particularly well the many-worlds interpretation. The concepts of “elements of reality” and “weak-measurement elements of reality” obtain a clear meaning in worlds with particular post-selection, while they have no ontological meaning in the scope of physical universe which incorporates all the worlds.​
Price's theorem depends on Discreteness (single outcomes, as pointed out in P&L's paper) just as P&L's depends on Assumption V.1, (Single-world) Realism.
Does OTS even make sense on a global level? It's about running experiments - which can only be done on a branch level.
I wish there was more work than Vaidman's directly addressing many worlds and OTS (in terms of real experiments), but at least I don't see anyone demonstrating counter claims.
That would be true retrocausality - the past being determined from the present. My issue with retrocausality is "where did the present come from?".
I do mean Everett's theory, though I find the term unitary QM more clear. And I think of the Born rule as a measure of world volume. If you mean the version of parallel lives where each agent has their own copy of ##\Psi##, it is more clearly local. But it seems like cheating to me - each individual ##\Psi## should also contain copies of the other agents with their own experiences and those are just as local as unitary QM.
EDIT: Ignore this, I think I have a better approach below.
In their paper it does though, how does it not. Genuinely I'm not seeing it, they posit its physical effects.
I know Vaidman's papers on this, but they are just a sketch of how it might work, is their any proof in general that it does work?
Regardless of general arguments like this, take Price's photon beam splitter experiment, can you show me how Many-Worlds replicates OTS in a branch for that (for general coefficients), it seems to me that by inspection even within a branch it does not. That's what Pusey-Leifer mean, it manifestly does not obey it. If they're wrong fine, but it seems clear to me that even observers within a branch would see OTS violated.
Their proof assumes single-world Realism, hence it can't tackle multiverse theories in general, but Many-Worlds seems to explicitly violate it as they say.
Let's say take the case with ##x \in \mathbb{Z}_2## and ##y## similar, classical probabilities for selection in ##x## preparation being ##\frac{1}{3}, \frac{1}{2}## in both cases. Easiest case probably being ##x## and ##y## involving preparation at different angles displaced by ##\frac{\pi}{4}##.
I might start a thread on Aravind-Mermin in Many-Worlds, as it seems confusing to me how each of outcomes at Alice and Bob's locations "know" that they are to pair up with worlds of the other observer in specific combinations without some nonlocality.
I think this can be resolved much easier, directed at @akvadrako .
Firstly, do you accept Many-Worlds lacks OTS in its fundamental ontology, i.e. as a whole, not within a branch?
I think this is just about different notions of "deterministic". In MWI, the entire many-worlds ontology evolves deterministically. But for the experience of observers within that ontology, what they experience is completely nondeterministic.
OK, no real disagreement, I guess it comes back to semantics. To me, Bohmian Mechanics is deterministic because knowledge of all variables would (in principle) lead to a certain outcome (even though such knowledge is not possible) for an observer. To me, MWI is not deterministic precisely because that same thing is not possible. Your prediction will always be expressed as a chance of an outcome, and there is fundamentally no amount of knowledge that would change that.
Yes, it is. If you know the exact wave function of the entire system at one instant of time, you can predict the wave function at all future times exactly. In practice we never know the exact wave function of an entire system, but that doesn't make the MWI not deterministic, any more than our inability to know in practice the exact state of a system in Newtonian mechanics makes Newtonian mechanics not deterministic.
In the MWI this is problematic; the question of how probabilities arise in the MWI (or, as it's more often stated, how the Born rule arises in the MWI) is one of the key issues with it, because according to the MWI taken at face value, there are no probabilities at all: everything is deterministic.
To put this another way: according to the MWI, taken at face value, if you are about to make a measurement of the spin of a qubit, say, you should not predict that you will see spin up with some probability and spin down with 1 minus that probability. You should predict that you will split into two copies, one of which sees spin up and one of which sees spin down (and each copy will be correlated with the appropriate state of the qubit). How you get from that to what we all actually predict in QM (that you will see spin up with some probability and spin down with 1 minus that probability) is, according to critics of MWI, not adequately accounted for.
Thanks for taking the time to explain some of the nuances of MWI. Admittedly I am not sure how you get from knowing "the exact wave function of the entire system at one instant of time" to "you can predict the wave function at all future times exactly" after some series of measurements. It would seem that the Born Rule would come into play and the future wave function would no longer look the same.
Anyway, I'm satisfied. :smile:
In MWI, the wave function is always the wave function of the universe - that's the whole point of the ''world'' aspect. This ensures determinism. Measurements happen inside the universe (deterministically, dependent upon preparations, parameter settings, and intentions of the experimenters), in a way not precisely specified by MWI. Hence its vagueness...
From the standpoint of the MWI, a "measurement" is just an interaction between different subsystems of the total system (which is the whole universe if we take things to their logical conclusion) that entangle the subsystems. These interactions are realized by unitary operators (basically ##\exp i H t##, where ##H## is the full Hamiltonian including interaction terms), so the time evolution they induce is deterministic and reversible.
I can see now I have some studying to do. There are key elements of MWI I am clearly ignorant of.
I recommend Travis Norsen's chapter on it in his book "Foundations of Quantum Mechanics: An Exploration of the Physical Meaning of Quantum Theory"
OTS is not part of it's ontology of course but it's ontology isn't operational, so I don't understand how it makes sense.
Just to clarify; when I say I'm using Everett's version of the theory, I don't mean his definition of world/branch, but just the objective part of the theory. I am not sure an exact definition is even possible without understanding the dynamics of an agent (or life), though the one used in the TSVF paper seems vaguely reasonable.
I'll ignore the rest of the post until I see your other point, though I have one avenue to investigate still. I also want to mention that I don't know how to do my own analysis; I mostly just read papers and try to put the pieces of the puzzle together from what's already shown. For now, I find it higher priority to maintain a high-level overview of the literature. Maybe I'm slow but even on this rather specific topic that takes a fair chunk of time.
This would be interesting, though if someone did discover any nonlocal (hidden) effects in MWI, I would be very surprised.
They don't have to "know" anything. All of the measurement interactions are local; there is nothing to "pair up". In terms of Bell's Theorem, the MWI violates one of the assumptions that underlies the theorem, namely, that measurements have single results. So the theorem does not apply to the MWI.
I'm not sure about this, I think even in the field it is considered an open problem as to whether Many-Worlds is nonlocal in some sense, see Travis Norsen's book I mentioned above.
I know MWI violates one of the ontological framework axioms (and so escapes most results in quantum foundations) however that doesn't mean it automatically has the properties the no-go results typically prevent, e.g. just because you aren't covered by Bell's theorem doesn't necessarily mean you are local.
For example in the Aravind-Mermin case Alice's world splits locally into one of sixteen worlds, then Bob's world splits locally into sixteen worlds. This naively gives 256 possible worlds, however if Alice and Bob fly toward each other only worlds with common values for the shared vertex in the Aravind-Mermin Pentagram can meet/interact, i.e. there is only 128 worlds.
How during the initial local splittings do same vertex splittings emerge into the same world?
In some sense it wouldn't be too surprising if Many-Worlds was nonlocal as spacetime is only an illusion of a sort that exists in the quasi-classical branches that appears once an environment has emerged that a position basis can decohere against. The wavefunction naturally lives in a configuration space.
Yeah the reason I switched is that I thought the original version would be way too long and detailed, in fact you'd probably have a paper at the end (i.e. a correction to Pusey and Leifer!)
See the book by Travis Norsen I mentioned above to @PeterDonis . It's an open problem as to whether Many-Worlds is strictly local.
That doesn't matter too much, remember the Pusey-Leifer theorem is about seeing if a theory has an ontological symmetry that directly reflects OTS, this is defined as Ontological Time Symmetry, see p.8
The only thing I'm asking is if you agree Many-Worlds lacks such an ontological symmetry. The definition makes sense to me when applied to Many-Worlds and I would say it violates it at a global level.
Leifer's reply to Tim Maudlin here might help:
https://arxiv.org/abs/1708.04364
The initial historical explanation part.
I will take a look. In general I agree it's an open question; the only proof of locality I'm aware of is Vindication of Quantum Locality (Deutsch, 2011), but I know it's not totally accepted.
