Quantum tunneling and radioactive decay.
3 replies · 11K views
bayan
The edge of a nucleus can be roughly modeled as a square potential barrier. An alpha particle in an unstable nucleus can be modeled as a particle with a specific energy, bouncing back and forth between these square potential barrier.
Consider a nucleus of radius r and an alpha particle with kinetic energy E (i.e., let the potential energy within the nucleus be zero) and mass m.
Assuming that the alpha particle moves along a diameter of the nucleus and that it moves at low enough speed that relativistic effects are negligible, what is the time tau between successive encounters between each edge of the nucleus and the alpha particle?
Express your answer in terms of [itex]K_{e}[/itex], [itex]r[/itex], and [itex]m[/itex].
[itex]K_{e}=mv^{2}[/itex]
[itex]v^{2}=\frac{(2r)^{2}}{t^{2}}[/itex]
[itex]\frac{K_{e}}{m}=\frac{(2r)^{2}}{t^2}[/itex]
[itex]\sqrt{\frac{K_{e}}{m}}=\frac{2r}{t}[/itex]
[itex]2r\sqrt{\frac{m}{K_{e}}}={t}[/itex]
Have I used the right approach to this problem? and have I got the correct answer?
Thanks in advance
Seems like the answer does not need the 2 in my answer, which means I have made a mistake in my approach or calculation. Anyone able to help out?
Thanks.
I'm not really sure about your approach, but there is a factor of half missing in your KE equation:
[tex]K_e = \frac{1}{2}mv^2[/tex]
Does that help?
Does that help?
I should hope so, lol
