Whitestar
- 90
- 4
Recently, I posted a thread on theories on teleportation:https://www.physicsforums.com/showthread.php?t=44179I discussed about how the transporter in Star Trek operates and why it would never work. Any procedure that convert matter to energy would be deadly and reconstruct person from this energy is a clone, not the original. In addition, the disassembly of crew members at the atomic level is not a viable option either due to the Heisenberg Uncertainty Principle. However, there may be a way to teleport a human: quantum tunneling.Today I read an article on the net about quantum physics and in one section, the author mentions about quantum teleportation. Here is a quote from the author:"Teleportation: As the probability wave suggests, you can get from Point A to Point C without necessarily passing through Point B. Small particles can jump from one location to another without actually moving through space between points, which is sometimes called a 'quantum leap'. In theory, this could be extended to larger particles."And here is the link:http://www.rotten.com/library/religion/quantum-physics/In Quantum tunneling a particle can bypass a barrier and appear on the other side of it without traveling thru it. The process is responible for radioactive decay of elements where an alpha will tunnel out of the nucleus of Uranium atom and then under go beta decay. Electronic use Quantum tunneling of electron in certain transitor (such as a Tunneling diode).Now Quantum tunneling is due to the fact that particles have a wave function. This Wave function is the possibility of a particle being at speciific location. If you could control this possibility wave you can transport a particle to any location that it could have travel to or will travel to. Do this with a person, and you could teleport him without turning him to energy or breaking him down into his basic molecules and beaming him.All you would need is to know his wave function (yes people have a wave function, and even the universe can be express as one) and alter it in a manner (how I have no idea) that alter his possibility of his location to place him where you wish him to be. He would suddenly be at that location, in a instant.All that is require is finding a way to manipulate the wave function of the particles involved. We do this all the time to beams of particles like photon and electrons. Take the double slit experiment for example. By closing and opening a single slit we can determine whether particle like a photon, proton,neutron or electron behave like wave or steams of particles.Not only can we effect the path the particle take but actually where it impact on the target, without applying a physical force to the particle itself. basically we are shaping the possiblitily wave in a manner that defies common logic and how this is done is one of the mystery of modern physic.What causes the Quantum wave form to collaspe, determining when or where a particle appears. We know when we attempt to measure a particle it happen, but the mechanism of how it happen is unknown. If we knew how the Wave function is force to collaspe then we may be able to effect the outcome.We could at will make a collection of particles like a human behave like a wave and then change the location by forcing the wave function to collaspe with the possibility that he some where else.
What does everybody else thinks?Whitestar
