Using the Sloan Digital Sky Survey to Extract Quasar Spectra and Fit Models
  • Context: Graduate
  • Thread starter Thread starter quasarLie
    Spectra
The discussion centers on utilizing the Sloan Digital Sky Survey (SDSS) to extract quasar spectra, specifically focusing on the process of locating and analyzing quasars using their Right Ascension (A.D.) and Declination (Decl) coordinates. Participants shared methods for accessing spectra through the SDSS SkyServer, including downloading data in CSV or FITS formats. Key parameters discussed include redshift, Lyman Alpha line shifts, and the significance of the BestFit and skyFlux columns in spectral data. The conversation highlights the importance of understanding these parameters for accurate quasar analysis.
  • Familiarity with the Sloan Digital Sky Survey (SDSS) tools and datasets
  • Understanding of astronomical coordinates: Right Ascension and Declination
  • Knowledge of redshift and its implications in astrophysics
  • Basic comprehension of spectral data analysis, including flux measurements
  • Explore the SDSS SkyServer for additional quasar spectra and data extraction techniques
  • Research the concept of K-correction and its application in astronomical observations
  • Learn about spectral fitting models and their parameters in astrophysics
  • Investigate the significance of the Lyman Alpha line in quasar spectra analysis
Astronomers, astrophysics students, and researchers focusing on quasar studies and spectral analysis will benefit from this discussion, particularly those interested in utilizing SDSS data for their research.
quasarLie
Hello,
I was wondering if anyone here had experience using the dataset of the Sloan Digital Sky Survey, i want to exract quasar's spectra (precise quasars of which I have the reference).
Thanks
Astronomy news on Phys.org
If you know the positions or the names, you can just go to the SDSS skyserver. Here is an example of a quasar with a redshift of 0.84. To see the spectrum, just click on the spectrum in the lower right. If you click on "Quick Look", you can also download the spectrum as a CSV or FITS file, or explore it with the interactive spectrum tool.
http://skyserver.sdss.org/dr14/en/tools/chart/navi.aspx?ra=10.17383414&dec=0.09007143&scale=0.2This link also shows you how to search for quasars.
It's also fun just to pan around. If you turn on the "Objects with Spectra" then objects that have measured spectra will have boxes around them. The link below shows a bright broadline quasar at Z=2.5.
http://skyserver.sdss.org/dr14/en/tools/chart/navi.aspx?ra=10.14253&dec=0.23243&scale=0.2
Vizier is a very good source for astronomical catalogues. It should have all the SDSS releases. You can even sort the data yourself, if so desired.
Thank you for your answer, i m trying to find spectra for this quasar for example. Can you hgelp me with it please there is a lot of parameters I am a bit lost
nomLQAC type A.D. Decl. redshift u_SDSS b_unknown g_Gaia v_unknown g_SDSS r_SDSS i_SDSS z_SDSS J_2MASS K_2MASS
LQAC_138+060_011 QUASAR 138.2684968514 60.0162492586 3.408 26.855 0.0 20.352 0.0 21.11 20.235 19.902 19.968 0.0 0.0
Here it is:
http://skyserver.sdss.org/dr14/en/t...ra=138.2684968514&dec=60.0162492586&scale=0.2
You just type the A.D. number (138.26849.. I'm not sure what A.D stands for, but this is the Right Ascension in degrees) in the ra line, and the Decl number (60.162...) in the dec line and hit search and it pops up. I'm sure this is the right object, because the redshift (z=3.408) and the magnitudes (like u_SDSS = 26.855 etc.) match.
The spectrum is in the lower right. This guy is a looong ways away. Note the LyAlpha line is shifted all the way from its rest wavelength of 1215 Angstroms into the visible at about 5400 Angstroms.
Do you understand what all of the parameters in your line are?
phyzguy said:
Here it is:
Thanks a lot, I did it but i wanted to be sure :p yes I understand what the parameters are. But why the LymanAlpha line is shifted ?
Do you understand what redshift is?
Yes I know what redshift is, and to correct it I have to use K correction??
If you understand redshift, what did you mean when you asked why the Lyman alpha line is shifted? What is the rest wavelength of Lyman alpha? Can you tell me where you would expect to find the Lyman Alpha line in a source with z=3.408?
K-correction is used to correct the filter magnitudes. It isn't used when dealing with spectra.
OK thanks, and do you know why it is written STar in the object type while i am putting Quasar's informations??
I don't know for certain, but I think it was originally classified as a star when it was chosen as a target, and only later re-classified as a quasar after examining the spectrum.
Thanks, when i download the spectra i have 4 columns wavelength flux bestfit and skyflux. Do you know what they mean by BestFit and skyFlux please?
In addition to measuring the spectrum, they fit a model to it. The model includes the type of galaxy, the redshift, and other parameters. The BestFit column is the prediction of the model. In the plots you can see the model plotted in addition to the measured spectrum (I think the BestFit is in black and the measured flux is in gray). The skyFlux is the part of the measured flux which is not from the quasar, meaning it is from the sky background. The night sky is not perfectly dark - there is always some light coming from the sky even if there is no star or galaxy there. Ideally you want the object flux to be much larger than the skyFlux. The larger the skyFlux is compared to the object flux, the more uncertain you are about how much of the measured flux is actually from the quasar.
  • · Replies 80 ·
26K
