Query runs fine in MySQL, but returns empty list in Python
  • Topic: Python
  • Thread starter Thread starter Wrichik Basu
    Data Position
7 replies · 7K views · last reply
Insights Author
I have a database that looks like this:
I want to get the "leaderboard position" of a particular member. The idea is to order the data by the score column, and then retrieve the row position of that particular member id. This is my query in MySQL:
[CODE lang="sql" title="MySQL"]SET @rowNum := 0;
SELECT rowNum
FROM(
SELECT (@rowNum := @rowNum + 1) AS rowNum, member_id
FROM members
ORDER BY score DESC) tmp
WHERE member_id = 288745911563241;[/CODE]
This works as I want in MySQL, returning the appropriate row number:
But, when I try to do the same via mysql.connector in Python 3.12, I get an empty list. This is my code in Python:
Python:
import mysql.connector
mydb = mysql.connector.connect(host="localhost", user="user_name",
                               password="pwd", database="db_name")
mycursor = mydb.cursor()
def main():
    mycursor.execute("SET @rowNum := 0; "
                     "SELECT rowNum FROM( "
                     "SELECT (@rowNum := @rowNum + 1) AS rowNum, member_id "
                     "FROM members "
                     "ORDER BY score DESC) tmp "
                     "WHERE member_id = 288745911563241;")
    print(mycursor.fetchall())
    mycursor.close()
    mydb.close()
if __name__ == '__main__':
    main()
Any idea why I am facing this?
In case anyone wants to test, this is the code for the dummy database:
SQL:
CREATE DATABASE db_name;
USE db_name;
CREATE TABLE members (
    member_id BIGINT PRIMARY KEY NOT NULL,
    score BIGINT NOT NULL,
    correct BIGINT NOT NULL,
    wrong BIGINT NOT NULL,
    highest_valid_count BIGINT NOT NULL
INSERT INTO members VALUES
    (115366974582, 5, 12, 7, 20),
    (588412336974, 25, 78, 53, 105),
    (144865512587, 2, 98, 96, 50),
    (255418963314, 31, 51, 20, 65),
    (5221479632215, 12, 25, 13, 52),
    (25596418873641, 23, 81, 58, 31),
    (75532184413259, 41, 51, 10, 96),
    (288745911563241, 9, 23, 14, 10);
Could be all sorts of reasons why it doesn't work, but a robust (and probably more efficient) way to do this is to use two queries, one to get the member's score and another to COUNT the number of rows with a higher (or higher-or-equal) score.
  • Love
jedishrfu said:
My first thought can execute() function process multiple sql statements?
I tried splitting into two execute() statements, but it was not working. Now I tried it again and it is working. Programming can be spooky at times!
Indeed, that's the best approach. Selecting less data means lesser memory overhead, especially for a bot that's supposed to be online all the time. Thanks a lot!
I'm not a python expert but don't you need an iterator to process the result as in:
Code:
iterator = cursor.execute(operation, params=None, multi=True)
See:
Code:
operation = 'SELECT 1; INSERT INTO t1 VALUES (); SELECT 2'
for result in cursor.execute(operation, multi=True):
if result.with_rows:
    print("Rows produced by statement '{}':". format(result.statement))
    print(result.fetchall())
else:
    print("Number of rows affected by statement '{}': {}".format(result.statement, result.rowcount))
https://dev.mysql.com/doc/connector-python/en/connector-python-api-mysqlcursor-execute.html
This would probably be a statement handle in ODBC.
Regards.
How do you resolve ties? The RANK() or DENSE_RANK() window functions will resolve ties for you (see here), but you will have to rank all the scores before querying results for individual members. If you need to do that multiple times, then it makes sense to do the calculation once in a temporary table and then query that.
Code:
DROP TEMPORARY TABLE IF EXISTS ranked_by_score;
CREATE TEMPORARY TABLE ranked_by_score AS
SELECT
member_id,
score,
RANK() OVER w AS 'rank',
DENSE_RANK() OVER w AS 'dense rank',
ROW_NUMBER() OVER w AS 'row_number'
FROM members
WINDOW w AS (ORDER BY score DESC);
My advice here is for you to abstract this into a higher-level representation of your data (using an ORM or even a query builder). My recommendation here is https://www.sqlalchemy.org/
This will be the first of many if you don't migrate your code to a more maintainable and repeatable structure
As other's have suggested, by default, executor does not handle multiple statements. The mysql docs: https://dev.mysql.com/doc/connector-python/en/connector-python-api-mysqlcursor-execute.html show that there is a multi=True parameter that you can pass into it, but it's also just as easy to just split them into two execute statements:
Python:
def main():
    mycursor.execute("SET @rowNum := 0;")
    mycursor.execute("SELECT rowNum FROM( "
                     "FROM members "
    mycursor.close()
    mydb.close()
    main()
Honestly, from a code readability perspective, I like this more, anyway.
