How Does Part (a) Help Solve Part (b) in This GCSE Math Problem?
  • Thread starter Thread starter thomas49th
    Gcse
This discussion focuses on solving a GCSE math problem that involves two parts: (a) solving the equation \(\frac{3}{x}+\frac{3}{2x} = 2\) and (b) using the result from part (a) to solve \(\frac{3}{(y-1)^{2}}+\frac{3}{2(y-1)^{2}} = 2\). The key insight is that substituting \(x = (y-1)^{2}\) transforms part (b) into a form similar to part (a), allowing for the application of the previously found solution \(x = 2.25\). The final solutions for \(y\) include both \(y = \frac{5}{2}\) and \(y = -\frac{1}{2}\), emphasizing the importance of considering both positive and negative roots.
  • Understanding of algebraic fractions and equations
  • Knowledge of completing the square and quadratic equations
  • Familiarity with substitution methods in algebra
  • Ability to manipulate rational numbers and square roots
  • Study substitution techniques in algebraic equations
  • Learn about completing the square for quadratic equations
  • Explore the properties of rational numbers and their simplification
  • Practice solving GCSE-level math problems involving fractions and quadratics
Students preparing for GCSE mathematics, particularly those focusing on algebra and problem-solving techniques. This discussion is beneficial for anyone looking to improve their understanding of algebraic manipulation and equation solving.
thomas49th
(a) \frac{3}{x}+\frac{3}{2x} = 2
that is 4x = 9 so x = 2.25
(b) I can do the first question (a) easy peasy , however the secnond question says "using your answer to part (a), or otherwise solve:
What part of (a) do I use to solve part (b)
for (b)
1) Expand (y-1)² = y² - 2y + 1
2) Expand 2(y-1)² = 2(y² - 2y + 1 ) = 2y² - 4y + 2
3) Double 1'st fraction to get equal denominators then add fractions
\frac{6}{2y^{2} - 4y + 2}
4) Crossmultiply so you get 3 = 4y^{2} - 8y + 4
then complete the square
(4y - 4)² - 16 + 4 = 3
y = \frac{4 +- \sqrt{15}}{4}
but that GETS a bit complicated for NON CALCULATOR level so i tried using the formula which gave me y = 1 or 1 (when at the bottom of the question there is 2 answers). Have I made a mistake in my calculations, and what about using part (a) to help answer part (b), I havn't done that, how do they link in together?
Thx
:smile:
You don't need to do anything like that. The clue is in the "using your answer to part (a)" part of the question. Do the two equations look similar? Can you spot a substitution of variables that will change the equation in (a) to that in (b)?
If its a non-calculator paper I'd suggest leaving that 2.25 as a rational. It will be easier to simplify later on in the question. Just an extra bit of advice :smile:
(b)l is like (a)... the first fraction is doubled to make equal denominators, both factions added together equal 2 and both have same nuerators.
so
\frac{6}{2(y-1)^{2}}+\frac{3}{2(y-1)^{2}} = 2
\frac{9}{2(y-1)^{2}} = 2
yet I am still not using my answer to part (a)... I am missing somthing arn't I
Thx
How would you turn the fraction in part (b) into the fraction in part (a)?
Suppose if you substituted x=(y-1)^2 into the second equation. What form does the equation turn into?
it turns into the one from part (a). So where saying x is now the quadratic y² - 2y + 1?
So if x=\frac{9}{4} from part (a) and x=(y-1)^2 how will you solve for y?
(y - 1)² = 9/4
y² - 2y + 1 = 9/4
then do i just complete square/use quadratic formula?
So you have (y-1)^2 = \frac{9}{4}. You can simply take the square root. There is no need to factor this.
so y-1 = 3/2
y = 1/1 + 3/2 = 2/2 + 3/2 = 5/2
so
y = 1\frac{1}{2}
cheerz
so y-1 = 3/2
so
y = 1\frac{1}{2}
cheerz
You're missing a solution-- remember you said there was space for two solutions? Well, if (y-1)^2=x then (y-1)=\pm\sqrt x.
And I hope you understand the importance of keeping numbers as rationals on the non-calculator paper. You probably would have lost a mark for an answer like \pm\sqrt{2.25} +1.
Good luck for next Monday!
yeh I do, wouldn't of spotted 9/4 being good to root. super duper
Thx
  • · Replies 17 ·
