Question about calculating moment of inertia.
Calculating the moment of inertia depends on the shape and mass distribution of the object. The formula I = 1/2 mr² is used for solid shapes like cones because it accounts for the distribution of mass across the volume. In contrast, I = mr² applies to point masses or collections of point masses at the same radius, such as in a ring. For solid spheres, the integration process to derive the moment of inertia has not been completed in the example referenced, which is why a different factor appears. Understanding these distinctions is crucial for accurate calculations in physics.
Zheng_
I was learning how to calculate moment of inertia on Youtube, and I'm confused about when to use 1/2 mr2 instead of mr2.
This video says that he used 1/2 mr2 instead of mr2 because the cone is solid
But in this video, while he was calculating a solid sphere,
he used mr2.
Can someone explain to me why and when should I use mr2 please?
I=mr2
I=mr2
Maybe it's because he was trying to calculate the solid sphere by separate it into four pieces and add them together after it? But it's still solid doesn't it?
The calculations for moment of inertia are different for different mass concentrations. You might see different equations depending on the type of shape and other contributing factors. Look at this link: http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html
Look at the common moments of inertia section.
Likes Zheng_
For the cone, the calculation is being done by leveraging earlier results. The cone is being divided it into circular slices. Because the cone is solid, each slice is a disk, which is why the factor of 1/2 is there. If the cone were hollow, each slice would be a ring, so you wouldn't have a factor of 1/2.
The video you linked is for a flat disc, not a solid sphere.
The mr2 formula is for a point mass, or for a collection of point masses all at the same radius in the rotation (such as a ring). All other formulae are obtained from this by suitable integration. In the case of ½mr2 for a disc, that integration has been done and produced the factor ½. I am guessing that where you see the mr2 in the solid sphere calculation the integration has not been done yet (and it will produce a different factor).
14K
  • · Replies 40 ·
