Question about Carnot theorem proof
The discussion revolves around the Carnot theorem and its implications regarding the efficiency of reversible and irreversible engines operating between two thermal reservoirs. The original poster questions the validity of the proof by considering a scenario where a reversible engine is placed in the position of an irreversible engine, suggesting that this might also lead to a violation of the second law of thermodynamics.
  • Participants explore the implications of engine efficiency when reversing the roles of a reversible and an irreversible engine. They question whether the assumptions made about the efficiencies hold true when the engines operate in different directions.
Some participants have provided insights regarding the differences in efficiency when engines operate in reverse compared to forward. There is an acknowledgment of the need to clarify the definitions of efficiency in these contexts, and the discussion is ongoing with various interpretations being explored.
Participants note the potential for confusion regarding the definitions of efficiency for engines running in different directions and the implications this has for the second law of thermodynamics. There is a recognition of the constraints imposed by the Carnot theorem in relation to the efficiencies of the engines discussed.
Ruby_338
Carnot theorem states that no engine working between two temperatures T1 of source and T2 of sink can have a greater efficiency than that of the Carnot engine.
Second law of thermodynamics:it is impossible for a self acting machine to transfer heat from a body at a higher temperature to a body at a lower temperature.
Consider a reversible engine R and an irreversible engine I. The engines are coupled such that as I runs forwards, it drives R backwards. I absorbs heat Q1from source, performs work W and and rejects heat Q2= Q1 - W to the sink.
Efficiency of I, μI = W/Q1
The engine R absorbs heat Q'2 from the sink, work W is done on it and it rejects heat Q'1to the source
Efficiency of engine R, μR= W/Q'1
Suppose, I more efficient than R. Then
μI > μR or W/Q1> W/ Q'1 so
Q'1>Q1
The source loses heat Q1 to I and gains heat Q'1 from R
Net heat gained by source per cycle is. Q'1- Q1 which is positive since Q'1 greater than Q1
The sink gains heat Q1- W from I and loses Q'2 to R.
Net heat lost by sink per cycle = Q'2 - (Q1-W). = Q'2- {Q1 -(Q'1-Q'2)}
= Q'1- Q1
The compound engine IR is a self acting machine which transfers heat from the sink(at lower temperature) to the source (at higher temperature) without any external agency, which is against the second law of thermodynamics.
My question is: if we put R in I's place and
, assume R more efficient than I, then using the same procedure as above, won't we find that heat would still flow from sink to source? Does this not also violate the second law of thermodynamics? Is the proof valid?
Efficiency of an engine, μ= W/Q1= (Q1-Q2)/Q1
Where W is work done by engine, Q1 is heat drawn from source by engine and Q2 is heat rejected to sink by engine.
Putting R in I's place,
Consider a reversible engine R and an irreversible engine I. The engines are coupled such that as R runs forwards, it drives I backwards. R absorbs heat Q1from source, performs work W and and rejects heat Q2= Q1 - W to the sink.
Efficiency of R, μI = W/Q1
The engine I absorbs heat Q'2 from the sink, work W is done on it and it rejects heat Q'1to the source
Efficiency of engine I, μI= W/Q'1
Suppose, R more efficient than I. Then
μI < μR or W/Q1> W/ Q'1 so
Q'1>Q1
The source loses heat Q1 to R and gains heat Q'1 from I
The sink gains heat Q1- W from R and loses Q'2 to I
= Q'1- Q1
When an irreversible engine runs backward, the ratio W'/Q'1 is not the same as the ratio W/Q1 for the same engine when it runs forward. (Otherwise, it would be a reversible engine.) In your second analysis you wrote
That's true if both R and I are running in the forward direction. But I is running backward.
The engines I and R in the second case are not the same engines I and R in
the first case. My bad.
the first case.
OK. But when you say that ##R## is more efficient than ##I## when operating between the same reservoirs, that means that the efficiency ##\left(\frac{W}{Q_1}\right)_R## for ##R## is greater than ##\left(\frac{W}{Q_1}\right)_I## for ##I## when ##I## is running in the forward direction. Efficiency of an engine is defined as ##\frac{W}{Q_1}## when the engine is run in the forward direction (i.e., ##Q_1## is heat input to the engine from the hot reservoir and ##W## is work output by the engine).
If you run ##I## in the reverse direction between the two reservoirs, the ratio ##\left(\frac{W'}{Q'_1}\right)_I## will not be the same as when ##I## is running in the forward direction. (Now, ##Q'_1## is heat output to the hot reservoir and ##W'## is work input to the engine.)
So, although it is true that ##\left(\frac{W}{Q_1}\right)_R > \left(\frac{W}{Q_1}\right)_I## when ##I## is running forward, it does not logically follow that ##\left(\frac{W}{Q_1}\right)_R > \left(\frac{W'}{Q'_1}\right)_I## when ##I## is running backward. But you assumed this latter inequality in your derivation.
Is it possible for efficiency of R to be more than the backwards running efficiency of
I for any engines I and R? Because in that case, net heat would flow from the sink to the source ( I think) which violates the second law of thermodynamics even though Carnot's theorem implies that R should be more efficient than I.
If net heat does not flow from sink to source, how can it be proven?
K. I got it. Thanks
10K
