Question about dielectrics in capacitors
  • Context: Undergrad
  • Thread starter Thread starter jaredvert
    Capacitors Dielectrics
The discussion centers on the role of dielectrics in capacitors, emphasizing that dielectrics, such as air or specialized materials, are essential for increasing capacitance without risking voltage breakdown. Using a conductor instead of a dielectric would lead to charge cancellation and significantly reduce the capacitor's effectiveness. The introduction of a conductor, even without contact, would effectively split the capacitor into two, halving the voltage rating and potentially doubling the capacitance, but with diminished benefits. The balance between maximum operating voltage and capacitance is crucial in capacitor design, particularly in electrolytic capacitors which utilize a thin dielectric layer for enhanced performance.
  • Understanding of capacitor fundamentals, including capacitance and voltage ratings.
  • Knowledge of dielectric materials and their properties.
  • Familiarity with the concept of voltage breakdown in electrical components.
  • Basic principles of electrostatics and charge polarization.
  • Research the properties and applications of different dielectric materials in capacitors.
  • Learn about the construction and functioning of electrolytic capacitors.
  • Explore the concept of voltage breakdown and its implications in capacitor design.
  • Investigate the design and applications of SuperCapacitors and their advantages over traditional capacitors.
Electrical engineers, electronics students, and anyone involved in capacitor design and optimization will benefit from this discussion, particularly those interested in enhancing capacitor performance through dielectric materials.
jaredvert
How come an insulator is put in between two capacitors? I realize it is to polarize the atoms and create a smaller electric field and hence smaller electric pressure/voltage and increase the capacitance. But why not use a conductor? Pretty much all the charge would cancel. OR am I missing a huge detail in that insulators actually TouCH the capacitors? If so then that explains why you couldn't use a conductor (since the charge would cancel) but why not use a conductor but just have it not touch either capacitor? Isn't that still polarization and the electric field become smaller? Please elucidate. Thanks
UltrafastPED said:
The dielectric fills the space between the plates (or coiled sheets) - it is simply a replacement for the air, which is also a dielectric.
How it works is explained here: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/dielec.html
But why not use a conductor, but just not have it touch the plates of the capacitor? That way no "leakage" but an effectively smaller electric field
The question seems pertinent to the definition of a capacitor "simply two conducting plates separated by some distance". Addition of another conductor in between them will be tantamount to splitting the capacitor into two capacitors such that:
Voltage rating of the each new capacitor was halved (if the introduced plate was of negligible thickness). Practically it will be reduced even more.
Capacitance of the individual capacitor would be doubled due to reduction of the new separation to half of the original one.
Now visualize these two "new capacitors" as if they were connected in series and see if they are different from the original capacitor i.e. before introduction of the mid plate. They are the same if the mid plate is of "zero" thickness. Otherwise it has degraded by all means - leaving no benefit to do that
Regards
Regards
I love that answer! Great job. Cookie for you!
My pleasure
Where should I send this cookie to?
In principle, you could fill the dielectric space with a conductor - leaving a minuscule air gap. That would produce a very high value of capacitance but a maximum operating voltage which would be ridiculously small, because the gap would break down so easily. Using an appropriate material as a insulator (dielectric) means that the ready polarisation of the dielectric allows a charge build up right next to each of the capacitor plates without voltage breakdown. So, in many respects, the dielectric gives the effect of a much smaller gap.
There is a compromise between Max Operating Voltage and Max Obtainable Capacitance, for any particular technology and allowable physical sizes for the Capacitor. Electrolytic capacitors are operated with a continuous offset voltage across them which deposits (electrolytically) a very thin layer of dielectric between the plates, giving a much higher Capacitance than if you were to use plastic / mica / paper etc.. See also the construction of SuperCapacitors (loads of Google Hits).
What is voltage breakdown exactly? How does it occur?
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 16 ·
