Question about ellipse and chord
  • Context: Undergrad
  • Thread starter Thread starter zyxwv99
    Chord Ellipse
The discussion focuses on calculating the distance from a chord to the end of an ellipse using specific dimensions. The ellipse is 23.5 mm wide and 21.5 mm high, with a chord measuring 15 mm long that is perpendicular to the major axis. To find the distance from the chord to the right vertex of the ellipse, one must determine the equation of the ellipse and the coordinates of the chord's endpoints. This approach leverages the mathematical properties of conic sections, specifically how ellipses are formed by slicing a cone.
  • Understanding of ellipse equations and properties
  • Familiarity with conic sections and their geometric interpretations
  • Basic skills in coordinate geometry
  • Experience with vector-based drawing tools
  • Study the mathematical equations of ellipses, including standard forms
  • Learn how to derive the coordinates of points on an ellipse
  • Explore the properties of conic sections and their geometric significance
  • Practice using vector-based drawing programs to create and manipulate ellipses
Mathematicians, graphic designers, and anyone interested in the geometric properties of ellipses and conic sections.
zyxwv99
I drew an oval using the ellipse tool of a vector-based drawing program. It's 23.5 mm wide and 21.5 mm high. There is a chord 15 mm long perpendicular to the minor axis. So the question is, how do I calculate the distance from the chord to the end of the ellipse (i.e., the end of the major axis).
(By the way, I've been wracking by brains trying to figure out an oval that's just a stretch-out circle could be a conic section. The best I can figure is a cone with an extremely small angle, cut diagonally many miles from the apex.)
http://lightcolorvision.wordpress.com/
(There a diagram near the top of this blog, entitled "Need help on this problem.")
Mathematics news on Phys.org
In the drawing at the blog entry, the chord is actually perpendicular to the major axis.
What I would do is figure out the equation of the ellipse, and then determine the coordinates on the ellipse of the endpoints of the chord, given that the distance involved is 15. Once you have the x coordinate of the endpoints, it's a simple matter to figure out the distance from the chord to the right vertex of the ellipse.
All of the conic sections arise from making slices in a cone, which by the mathematics definition, is in two parts - an upper cone portion and a lower cone portion. Away from mathematics, most people call one of these sections a "cone."
If you slice the cone perpendicular to the axis of the cone, you get a circle. If you tilt the angle at which you make the slice just a bit, you get an ellipse. Different angles generate ellipses with different major axes. If you slice the cone so that the plane of the slice is parallel to the opposite side, you get a parabola. Vertical slice, you get the two "sheets" of a hyperbola.
Thanks, Mark44. With your help I was able to figure it out.
