Question about exothermic/endothermic reactions
  • Context: Undergrad
  • Thread starter Thread starter Alexmer
    Reactions
Exothermic and endothermic reactions can indeed occur in a vacuum, as they do not rely on heat transfer to the surroundings. For instance, the decomposition of nitrogen trichloride (NCl3) releases 232 kJ/mol of energy, producing hot reaction products regardless of the surrounding environment. Similarly, the dissolution of ammonium nitrate (NH4NO3) in water demonstrates an endothermic reaction, where the solution becomes colder as it absorbs energy from the water molecules' vibrational and rotational motions. These reactions illustrate that energy changes can occur independently of external heat sources.
  • Understanding of thermodynamics principles, specifically exothermic and endothermic reactions.
  • Familiarity with chemical reactions and energy changes in reactions.
  • Knowledge of molecular interactions, particularly vibrational and rotational excitations.
  • Basic chemistry knowledge regarding compounds like ammonium nitrate and nitrogen trichloride.
  • Research the thermodynamic principles governing exothermic and endothermic reactions.
  • Study the energy changes associated with the decomposition of nitrogen trichloride (NCl3).
  • Explore the dissolution process of ammonium nitrate (NH4NO3) in various solvents.
  • Investigate the implications of conducting chemical reactions in a vacuum environment.
Chemistry students, chemical engineers, and researchers interested in thermodynamics and reaction energetics will benefit from this discussion.
Alexmer
I couldn't find the answer to this anywhere so I figured I'd make a thread.
Can exothermic/endothermic reactions occur in a vacuum? Or if there are no surroundings, then what would the transfer of heat be? Thanks.
Science news on Phys.org
My guess: exothermic - emit photons. endothermic - needs incoming photons.
Or end up with more or less thermal energy in the reaction products than in the initial reagents... That's certainly how I'd expect the (remarkably exothermic) decomposition of TNT to behave.
^ Exactly. The energy does not have to come from or go to the surroundings.
Lets use the dissolution of ammonium nitrate as an example of an endothermic reaction. If we put NH4NO3 and water in a thermos bottle or other heat-insulated container, what happens? The ammonium nitrate dissolves and the resulting solution is colder than the water originally was. The energy needed for the reaction has been taken from the vibrational/rotational excitations of the water molecules.
One example of an exothermic reaction is the explosive decomposition of nitrogen trichloride to form nitrogen and chlorine gases: ##2NCl_{3}\longrightarrow N_{2}+3Cl_{2}##. The compound can explode in vacuum just as well as in normal atmosphere, the energy change of 232 kJ/mol in the reaction just means that the reaction products are very hot when they are formed.
How can a vacuum contain reactants?
Regardless, the others are right; reactions do not require heat transfer to surroundings.
