Question about falling bodies
The discussion centers on the physical forces acting on a spherical object rolling down an angled surface, particularly the brief adherence to the surface. Key forces identified include gravity, friction at the contact point, and potential adhesion influenced by material composition and environmental conditions. Additionally, air resistance plays a role in the movement of the sphere. The conversation emphasizes that while the sphere may linger on the surface momentarily, it ultimately succumbs to gravitational pull and friction.
  • Understanding of basic physics concepts such as gravity and friction
  • Familiarity with the principles of motion and forces
  • Knowledge of material properties affecting adhesion
  • Awareness of environmental factors like air resistance
  • Research the principles of gravitational force and its effects on rolling objects
  • Explore the role of friction in motion, particularly in rolling scenarios
  • Investigate material science concepts related to adhesion and surface interaction
  • Study the impact of air resistance on moving objects in different environments
Writers, physicists, and educators interested in the dynamics of motion, particularly in fictional contexts where realistic physical interactions are essential for authenticity.
ggblk
What force(s) are at work when a spherical object, rolling down an angled surface, tends to adhere to the surface, if only for a short while? Does such a thing exist or am I playing fast and loose with the laws of nature?
Thanks
What do you mean by adhere? Are you saying the sphere is sticky and sticks to the surface?
Thanks for replying.
No, not sticky in the standard sense of the word. I was hoping there might be physical forces at work while the sphere was rolling that would make it less likely to depart from the surface -- if only for a few seconds.
This is for a work of fiction, so I'm less interested in exactitude as I am in giving the scene an authentic feeling.
If the surface is less than vertical, the ball will roll down it, otherwise, it will fall.
I realize that. The surface is only *slightly* less than vertical. What I'm asking is, what specific forces are at work?
there's the gravity force and there is the force of friction at the point of contact between the sphere and the surface.
When a ball sits on the surface, it might linger there for a moment because it takes time to accelerate after it's released. There might be some force of adhesion between the ball and the surface. Adhesion depends on the material structure and composition of the ball, surface, and the environmental parameters like temperature. There will also be some resistance from the air around the ball, which has to be displaced in order for the ball to move through it. I can't think of any other major forces involved, in a simple scenario.
