Question about increasing laser power
  • Context: Undergrad
  • Thread starter Thread starter Josiah
19 replies · 2K views
Josiah
TL;DR
Would this work?
Hi, Im not sure if this is the right forum to post this question. If you had a laser, then reflected it back on its self, and then reflected it back again, would this enable a super high powered laser? Because it would be continuously reflecting back on it self at the speed of light.
There are two kinds of lasers, continuous wave (CW) and pulse. Since you're thinking of CW, that is what I will address.
Most CW lasers work by reflecting light back and forth between two mirrors. A certain amount of energy is pumped into that system and that results in a monochromatic beam that (within some degree of precision) is in-phase with itself. One of the two mirrors will be only partially silvered (or in certain cases, missing) and so a portion of the laser beam crosses to the exterior and is available for use.
If both mirrors are 100% reflective, then you might think that the more energy you pump in, the more that would accumulate in the laser in the form of a steadily power-increasing laser beam. To some extent, this is true. But what will happen is that the elements responsible for pumping energy into the beam (the ionized gas, crystal, or semiconductor) will reach a limit where they are absorbing as much energy as they are pumping into the laser beam.
At that point, the laser beam will remain at that power limit (or possibly begin reducing) as the equipment uses the remaining energy to produce heat.
I believe that is how they work, up to a certain power (20W?). Trying to do that too much starts to melt parts. I am just a casual amateur, but here is an interesting YouTube video: I Built an Insane 260W LASER That Cuts Metal !
Of course, the military ones probably are a different thing entirely.
ADDED: A lot of the video comments say how crazy reckless it was. I'll leave this stuff to the experts and the nuts, and just enjoy the YouTube videos.
The answers above are correct. Just adding a safety note: any laser above ~500 mW (Class 4) requires proper eye protection, not just from the direct beam, but from diffuse reflections off walls, dust scattering, and
secondary reflections from ordinary surfaces. At 260W, scattered light alone can cause permanent eye damage.
Josiah said:
TL;DR: Would this work?
Virtually all lasers use this, or similar, techniques internally to function optimally. You won't make their design better by adding your own. In practice, retroreflections can cause significant problems in performance and reliability for lasers.
What you're describing is essentially a passive Fabry-Pérot cavity. This is actually a well-known setup — the intracavity field can be enhanced (roughly ~100× with good mirrors), but losses always set a steady-state
limit. You don't get infinite accumulation.
In practice, what works is using the cavity with a gain medium (i.e., a laser), where the feedback is actively maintained. Here's a thesis that explains how laser cavities and optical feedback work in detail: Laser feedback interferometry with semiconductor lasers
Keep in mind that even achieving a modest cavity enhancement requires lab-grade alignment (sub-micron precision), that is very hard to obtain on home made project.
Home built confocal (and similar) resonators aren't THAT finicky. Many people have built low performance, low reliability, and often higher cost lasers at home. It's OK as a maker hobby, but not the way to actually get a good laser. But resonator alignment isn't really very hard. Even I could align the mirrors on big commercial ion lasers with virtually no talent or training.
A true Fabry Perot resonator with (separate) flat mirrors really doesn't make a great laser*, as you implied, it's too finicky, even after alignment. Also, coupling a back reflection into a cavity with proper wavefront matching is just too hard and pointless IMO.
* But often quartz xtals are used as an intracavity BPF, they are built permanently aligned.
I don't understand, if the mirrors are 100 percent reflective, then why would they absorb the energy?
He didn't say the mirrors, he said "the ionized gas, crystal, or semiconductor" that's pumping energy into the beam.
No real mirror is 100 percent reflective, but that just adds additional losses on top of the ones @.Scott was referring to.
What if the parts didn't melt, how much power could it produce?
1.21 ggigawatts.
  • Haha
If I catch the spirit of you question, you will be gratified to discover that one can design a laser that will continue to operate as it is being vaporized. Project Excalibur created such a design. Had it been developed, it would have been most emphatically a pulse laser.
  • Agree
To clarify, refl
Sorry, I don't understand. If the elements pumping into the beam are continuous, why would they reach their limit?
Take the Helium Neon laser as an example. A current is applied across the gas mixture at a voltage over 1000V. That discharge excites the Helium atoms which in turn excite electrons in the Neon from their ground state to a higher state. The readiness of these electrons to fall back to their ground state and emit a photon in the process is what builds up the laser beam. But the laser beam itself is able to pull those same electrons into the higher state. Once the laser beam is of sufficient intensity, the Neon will bleed almost as much from the laser as it delivers. The "almost" is because there will be other energy loses that the laser system will be "powering".
if you could eliminate the bleeding of the neon, and stop other energy losses, would you create an infinately strong laser?
Right, jewelry and other reflective surfaces are an absolute no-go, and proper protection googles is a must. A fire-extinguisher probably wont harm either! :smile:
You are asking if we do impossible things, can impossible things happen. Yes.
Josiah said:
if you could eliminate the bleeding of the neon, and stop other energy losses, would you create an infinitely strong laser?
You're not going to generate a laser with "infinite energy". And, if you do, those safety goggles won't do you any good.
When you ask to eliminate the bleeding from the neon and other energy losses, you're not only setting aside any Engineering obstacles, you're also setting aside the characteristics of the neon. The same electron energy gap that makes He-Ne laser light red also makes the neon able to absorb that same red.
But you ask, what if I eliminated that?
Okay, I will exempt you from "real" neon. And allow me to predict some of your questions as I go through other issues:
1) A finite length laser of infinite energy would form a black hole of infinite diameter. The good news, even after falling through the event horizon (while wearing your goggles, of course), you will still enjoy a trip of infinite length before encountering spaghettification and singularities.
--- So, you then ask, what if our universe didn't do that?
2) You will need a power supply of infinite capacity and infinite time to charge the laser up.
--- You then say, I have the time and the power supply, now can do it?
3) The force against the mirrors will approach infinity.
--- Right - mirrors will be unbreakable and unmovable as well as unmeltable.
In that case, sure!
Let me know when you're done.
I also found this article which addresses similar questions.
You can't eliminate the laws of physics, because then we have no basis for giving any answer at all.
We can't answer questions that involve violating the laws of physics. The bleeding of the neon and the other energy losses are part of how the laws of physics work in such systems. You can try to minimize some of them, but you can't eliminate them--some, like the neon bleeding, are, as @.Scott has already explained, inherent to the very physical thing that makes the laser possible.
This also would violate the laws of physics.
