Question about isotope halflife and decay
  • Thread starter Thread starter furface
    Decay Isotope
The discussion revolves around understanding the concept of half-life in relation to the decay of the isotope 90Sr, which has a half-life of 28 years. The original poster struggles to determine how long it takes for 7/8 of the sample to decay, mistakenly calculating it as 49 years. However, the correct calculation shows that after three half-lives (84 years), only 1/8 of the original amount remains. The key takeaway is that each half-life reduces the amount by half, and the probability of decay applies to a large number of atoms rather than individual ones. The final understanding emphasizes the importance of correctly applying the half-life concept to solve decay problems.
furface
First off I just wanted to say something quickly. I am a Visual Arts major taking a Introductory Physics class for fun, (probably my favorite class that I have ever taken, also the most rewarding. I have learned so much that I wish I had taken it sooner so I could have pursued it more)
My physics professor gave out a study guide for our final with questions and their respective answers. I have been able to complete every question flawlessly except for one. I have tried everything that I have been capable of to solve this problem but I can not seem to figure it out (even researched online, but all results went over my head). So here we go.
The isotope 90Sr has a half-life of 28 years. How many years will it take for 7/8 of a sample of this material to decay (so that 1/8 is left)?
The solution to the problem listed in the answer key is 84 years.
This is where I have become confused, I really do not have notes for this type of problem, only for problems with a similar subject matter. The equation I have is \alpha= (2.7x10^-11)n [I am not sure how I would use these though, I feel like they do not work for this problem, I have used it on others]
I have tried quite a few things. I assumed that 28 years being the half life, is half of its life. So I thought maybe the full length of decay would be 28*2 which would be 56. Then I took 7/8 of that number to find out how long it will take to have 1/8 of it left. My answer for that was 49 years.
Is my train of thought correct in any way when it comes to this problem or am I missing something completely? I just need to be guided in the right direction so I can solve this myself when a similar problem comes along on the final.
Half-life of an isotope means the time period after the amount of the isotope is half of the original amount. If you had one million 90Sr atoms, you will have only half million after 28 year, so half million of the isotopes has decayed. After 56 years, you have a quarter million. This is halved again during the next 28 years, and so on.
If =7/8 of the isotopes decayed what fraction of the original amount of 90Sr is still present?
ehild
There would be 1/8 of the decayed isotopes present. If there were 1 million there would be 125,000 left.
So is the teachers solution to the problem incorrect? I see what you are saying but when I keep getting 84 years as 6/8 of its life having past, while for 7/8 I get 112 years.
After 28 years, you have half the original amount. After the next 28 year, 1/4 remains. It is halved again during the next 28 year. So after 3 times 28 years you have 1/8 of the original number of atoms. That 84 years is correct. The half life-time does not mean that a single atom lives for 56 years. It means that the probability that it still exist after a period of 28 years is 50 %.
ehild
Oh wow, thank you so much. I understand what I was doing wrong. Maybe it was because I was working so late I just was confusing myself.
Is this the correct train of thought?
1/2 life is 28 years
half of that half life is 1/4, which is 56 years
and half of 1/4 is 1/8 (which is how much I am looking for) which is now 84 years
Well, it is better to say "half alive" instead of 1/2 life... And do not forget, it is probability. Valid for high number of atoms. If you have only two atoms, you cannot say that one of them will decay exactly after 28 years.
In case of a more general problem, for example: how long have to wait till an isotope decays to 1/100 of the original amount, you can use the equation
N(t)/N(0)=2^{-t/\tau}
where N(0) is the initial amount of the atoms and N(t) is their number at time t, and tau is the half-life.
ehild
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
