Question about opposing magnets
Opposing magnetic fields from permanent magnets do not inherently degrade each other over time under stable conditions. However, factors such as the type of steel used in the magnets and mechanical vibrations can lead to demagnetization. The hysteresis curve plays a crucial role in this process; if the area within the curve is large, the magnet exhibits greater resistance to demagnetization. Manufacturers often employ a shaking process post-magnetization to ensure stability, but exceeding specified current limits in applications like PM motors can result in permanent performance loss.
  • Understanding of permanent magnets and their properties
  • Knowledge of hysteresis curves in magnetism
  • Familiarity with demagnetization processes
  • Basic principles of magnetic fields and forces
  • Research the effects of mechanical vibrations on permanent magnets
  • Study the principles of hysteresis in magnetic materials
  • Explore methods to prevent demagnetization in PM motors
  • Investigate different types of steel used in permanent magnets
Engineers, physicists, and hobbyists interested in magnetism, particularly those working with permanent magnets in applications like motors and magnetic levitation systems.
defmar
My fundamental question is, do opposing magnetic fields eventually degrade each other over time? If they do, is there a way to mitigate or eliminate their ability to degrade one another?
If I had one permanent magnet facing up and another permanent magnet facing down hovering over it (with the desired effect to keep it hovering, including the effect of gravity), would their fields eventually cancel each other out over time - or is there a way to keep it hovering, indefinitely, until the end of time, without introducing external energy inputs?
You are speaking of permanent magnets.
It depends on the steel used in the magnets. As for a steady state of the magnets, the answer is no. But if the magnets e.g. vibrate, the point in their magnetizing curve will be displaced some. This displacement will follow hysterisis-curves, and if these curves are not exactly closed, the magnets could be demagnetized. You could say that if the area within a hysterisis-curve is large, the magnet will be more rigid to demagnetizesation ( hope this is the right word ).
Manufacturers will, after having magnetized the magnets, "shake" them a bit magnetically, so that they are not extremely magnetized by delivery, but say you have some PM-motor and the specified max-current is excessed, the magnets will be demagnitized, and the performance of the motor will be decreased permanently.
  • · Replies 16 ·
