Question about Orbitals in an Atom
  • Context: Graduate
  • Thread starter Thread starter CRichard
    Atom Orbitals
8 replies · 3K views
CRichard
For a summer class, I’ve been trying to get the quantum picture of an atom at least in conceptual terms, no math. I understand how, if you think about an atom like a one-dimensional box, an s orbital is like the first fundamental wave, and a p-orbital is like a sine wave, and I understand how the p orbital has higher energy because of greater frequency. But how can you picture 2s and 3s, etc. orbitals? Are they like first fundamental waves with greater amplitudes? I thought that the frequency of a fixed string depends mainly on its length and tension, not amplitude, so if that's the case how does E = hv?
Also, how are they quantized, since can’t you “pluck” that string in a one-dimensional box however far you want (at least as far as it can stretch), and give it an infinite number of amplitudes? In other words, I get how the need to fit a whole number of half wavelengths into the box justifies the quantization of energy into s, p, d, etc orbitals, but what limitation prevents the s orbitals from having a continuous spread in energy?
A string is one-dimensional whereas an atom is three-dimensional. Crudely speaking, the "vibrations" are quantized in each dimension.
Again crudely speaking, the primary quantum number (energy level number) corresponds to quantization in the radial dimension. The s, p, d, f correspond to quantization in the "longitude" dimension (think of going north/south on a globe). Finally, there's a "magnetic" quantum number that corresponds to quantization in the "latitude" dimension (think of going east/west around a globe).
It might help to try to imagine standing waves of sound in a spherical cavity, but I can't find any pictures of those at the moment.
Thanks, that makes sense. The only thing I don't get is how E = hv is not violated for example in the case of a piano string. I remember reading that it doesn't matter how much energy you give to a piano string by striking it hard, the pitch is the same because frequency doesn't change. Shouldn't the added energy and loudness be the result of an increase in frequency?
E=hv is the energy of a single quantum. If you pluck a string harder, you are putting more quanta in it.
If you like, the generalization of the formula is E=nhv, where n is the number of quanta.
I don't know for sure, but I think a similar effect happens in a pendulum. Pushing either one harder only causes the amplitude to increase. The way both are built and react, the frequency will not change when you add more energy.
E = hv relates the frequency of light to the energy of a photon. It doesn't apply to a piano string.
No, frequency (pitch) and amplitude ('volume', intensity) are independent properties. A flute has a higher pitch than a kettle-drum, but it's not necessarily louder.
Doesn't it, though? My impression was that for a given mode of vibration, E = hv applies to the phonons in the lattice.
Recently, single phonons were added and removed from a mechanical mode of oscillation:
http://www.nature.com/nature/journal/v464/n7289/abs/nature08967.html
"E = hv relates the frequency of light to the energy of a photon. It doesn't apply to a piano string."
That's what I was thinking too, because you can have many water ripples too with a high frequency but low energy. But then, does E = hv also apply to matter waves like an electron wave?
Sorry to bump this. I can't seem to find a clear answer online, but just to clarify: if you think about the analogy of standing waves on a circular drum, a 2p orbital has electron density farther from the nucleus than a 1s orbital. So, I think it would have a higher energy because of the charge separation. But can you also think about it a different way, and say that the higher energy is due to the higher frequency of the p-orbital by the equation E = hv, (that matter waves are fundamentally quantized) or does this equation only work for electromagnetic energy?
