Question about the expanding Universe and the Andromeda Galaxy
The Andromeda Galaxy is approaching the Milky Way at a speed of 110 kilometers per second, contradicting Hubble's Law, which predicts a recession speed of 55 kilometers per second. This discrepancy arises because Hubble's Law applies to large-scale cosmic expansion, while local gravitational interactions dominate within gravitationally-bound systems like the Milky Way-Andromeda pair. The gravitational bond between these galaxies overcomes the effects of cosmic expansion, which is an average phenomenon derived from the Friedmann equation based on the universe's energy density. Thus, local dynamics must be analyzed independently of universal expansion rates.
  • Understanding of Hubble's Law and its implications in cosmology
  • Familiarity with gravitational binding in astrophysical systems
  • Knowledge of the Friedmann equation and energy density concepts
  • Basic principles of cosmological expansion and dark energy
  • Study the Friedmann equation and its applications in cosmology
  • Explore the concept of gravitational binding in galaxy clusters
  • Research the implications of dark energy on local versus cosmic scales
  • Examine case studies of galaxy interactions and their dynamics
Astronomers, astrophysicists, and students of cosmology seeking to understand the complexities of galaxy dynamics and the relationship between local gravitational forces and universal expansion.
abdossamad2003
Hi
If the universe is expanding, then why does the Andromeda Galaxy approach us? Does not it contradict Hubble's law?
Space news on Phys.org
Recession of galaxies is only seen at large distances, over 100Mpc, if memory serves. Essentially, all galaxies have some random motion on top of the uniform expansion, and for galaxies nearer than that the typical magnitude of the random motion is comparable or greater than that of expansion. So nearby galaxies (like Andromeda, not even 1Mpc distant) can be moving away from us, towards us, or purely transversely. Uniform expansion becomes the dominant effect beyond that.
This is because the universe is not and never has been quite completely isotropic. If it were genuinely isotropic, Hubble's Law would hold at all scales, but we wouldn't be there to see it because stars, planets, and people are part of the anisotropy.
abdossamad2003 said:
Hi
Because
- expansion is an overall average,
- objects such as galaxies have their own peculiar velocities, independent of the overall expansion,
- expansion is overcome on small scales by gravitationally-bound objects.
Hi
According to Hubble's law, the Andromeda Galaxy should move away from us at a speed of about 55 kilometers per second, but on the contrary, the galaxy is approaching us at a speed of 110 kilometers per second!
Yes. Hubble's Law isn't expected to apply on such small scales as the distance to Andromeda.
OK, so
1. the combined peculiar approach velocity of Milky Way/Andromeda is obviously 165km/s.
2. MW and Andromeda are gravitationally bound, so Hubble Law does not apply.
3. Hubble's Law is an average.
4. You're taking Hubble's Law too literally.Also, this:
Hubble's law applies to the universe as a whole and can be derived from the Friedmann equation, which depends on the energy density of the universe. If we input the average energy density across the universe we get expansion. If we analyse the energy density for the local cluster of galaxies we do not get expansion: we get gravitational attraction.
Overall, I came to the conclusion that the gravitational bond of these two galaxies overcomes expansion.
It's more than that. The very equations that produce the universal expansion rate do not apply to a volume of the universe that has high energy density.
The dynamics of the local cluster of galaxies have to be calculated specifically. It's not necessarily the universal expansion minus local gravity.
I mean, in addition to the gravitational expansion or dark energy, the Andromeda Galaxy's calculations have to be included in the calculations.
The space between MW and Andromeda is not expanding due to Cosmological Expansion.
It is not a-force-that's-trying-to-move-our-galaxies-apart-yet-being-countered-by-gravity.
Likewise, the atoms in your body (or even between the Sun and the Earth) are not being inexorably pulled apart by CE.
It does not apply within gravitationally-bound systems.
Andromeda's motion toward us is not a property of Andromeda. It is a property of the system. From an Andromedan's PoV, we're moving toward them.
Reread PeroK's post that you quoted. Take it to heart.
The amount of vacuum and hence dark energy in the local cluster is small compared to the average across the universe. The universal expansion rate depends on the overall energy density of the universe. The dynamics of the Andomeda-Mily Way system does not.
To illustrate this, we could consider two scenarios:
1) The current scenario where the universal expansion is ##70 km/s## per megaparsec.
2) A scenario where the universal expansion is much greater. Say, ##200 km/s## per megaparsec.
The question is whether the dynamics of the Andromeda-Milky Way system would be different in those two cases? The answer is no. This is because, as I said above, you have to calculate the dynamics of the Andromeda-Milky Way based on the local energy density. And, in both cases, the amount of dark energy in the system is the same and is independent of the overall energy density of the universe.
In other words, the collision between the Andromeda and Milky Way is not significantly affected by what the rest of the universe looks like. It's independent of the universe expansion.
This is why you cannot simply plug-in a uniform expansion rate of ##70km/s## per megaparsec. That's only the average across the universe. It's not something that happens everywhere on a local scale.
