Question about the Hamiltonian Operator
The discussion revolves around the Hamiltonian Operator as introduced in the context of the Schrödinger Equation, particularly focusing on the kinetic energy component. Participants explore the derivation presented by a professor in a physical chemistry course, addressing the mathematical underpinnings and conceptual clarity surrounding the topic.
  • One participant expresses confusion about the derivation of the eigenfunction-eigenvalue equation for kinetic energy involving Planck's constant, noting their limited background in physics.
  • Another participant critiques the professor's explanation as "hand-wavey" and suggests that the derivation is rooted in classical mechanics and relativity, recommending further reading from Ballentine's textbook.
  • A third participant attempts to clarify the derivation by providing a step-by-step breakdown of the equations involved, linking them to the definition of kinetic energy.
  • There is acknowledgment of a minor algebraic error in the provided derivation, with participants discussing the commonality of such mistakes in mathematical work.
  • One participant expresses gratitude for the explanations and shows interest in understanding how Schrödinger's equation relates to Einstein's relativity, while also recognizing potential challenges in the mathematics involved.
  • Another participant notes that while the mathematics is not beyond calculus, it can be complex and suggests that mathematical maturity may be necessary to tackle the proofs involved.
Participants exhibit a mix of agreement and disagreement. While some express confusion and critique the clarity of the professor's explanation, others provide alternative insights and clarifications. The discussion remains unresolved regarding the best approach to understanding the derivation and its implications.
Participants note limitations in their understanding due to the complexity of the mathematics involved, with references to advanced concepts that may not be accessible at the current level of study.
plazprestige
In my physical chemistry course, we are learning about the Schrödinger Equation and were introduced to the Hamiltonian Operator recently. We started out with the simple scenario of a particle in 1D space. Our professor's slide showed the following "derivation" to arrive at the expression for the kinetic energy component of the Hamiltonian (see attachment).
I do not understand how the professor arrived at the eigenfunction-eigenvalue equation for the kinetic energy involving Planck's constant. I understand that kinetic energy is equal to momentum squared divided by twice the mass, of course, but nothing beyond that in the slide. If someone could explain this, I would appreciate it. Please note that I am not a physics major, so any mathematics more advanced than calculus may be beyond me (I do understand operators and eigenfunctions, however).
Its basically hand-wavey rubbish given so you basically don't tell students its pulled out of a hat.
The reason for Schrodingers equation believe it or not is the principle of relativity of classical mechanics ie time is invariant. But proving so involves advanced math. You will find the derivation in Ballentine - Quantum Mechanics - A Modern Development - Chapter 3. At your level you probably won't understand it, but I do suggest you get a copy from your university library and have a look at it to get a bit of its gist.
As to how Schroedinger did it, which what your professor wrote is reminiscent of, check out:
http://arxiv.org/abs/1204.0653
But again its math is likely a bit beyond your level.
At your level I would have a look at the first two chapters of Griffiths - Introduction To Quantum mechanics.
Added Later:
I found the following that may help:
Thanks
Bill
The slide is very convoluted. I believe what he is doing is the following:
$$\frac{d^2 \psi}{dx^2}=-\left(\frac{2\pi}{\lambda}\right)^2 \psi$$
Multiple both sides by [itex]\frac{h^2}{8\pi^2 m}[/itex]
$$\frac{h^2}{8\pi^2 m}\frac{d^2 \psi}{dx^2}=-\frac{h^2}{8\pi^2 m}\left(\frac{2\pi}{\lambda}\right)^2 \psi$$
Remember that [itex]p=\frac{h}{\lambda}[/itex] so that the equation now can be written
$$-\frac{h^2}{8\pi^2 m}\frac{d^2 \psi}{dx^2}=\frac{4 \pi^2 }{8\pi^2 m}\left(\frac{h}{\lambda}\right)^2 \psi \\ -\frac{h^2}{8\pi^2 m}\frac{d^2 \psi}{dx^2}=\frac{1}{2 m}p^2 \psi $$
Now you see the right side is the definition of kinetic energy.
I concur with Bill's first sentence.
[EDIT: fixed what Bill pointed out in the next post]
Well spotted - but there is a minor algebraical error in the third equation - an extra h^2.
I generally don't worry about such things because its a good exercise spotting them - I make errors like that all the time - and I have to say its gotten worse as I get older.
Thanks
Bill
Ah, thanks! I made that error twice, but I only caught one before posting.
All errors are unspecified exercises for the reader.
Thank you both for your in-depth explanations. I figured that the professor was hand-waving, but it is nice to have at least some rudimentary idea of where the Hamiltonian (or the kinetic energy component) comes from. To Bill, I am familiar with the basics of Einstein's relativity, so I would be interested in hearing more about how Schrödinger's equation can be derived from that concept. If the math is way beyond calculus, then I suppose I won't worry about it.
The math isn't beyond calculus - but is pretty heavy going. I have an degree in math and for me it was slow going.
To see if you want to tackle it see the proof of a key theorem it uses, but the proof is left out:
http://arxiv.org/pdf/0808.0779v2.pdf
If you can understand that then Ballentine should be doable - in which case see chapter 3 - Ballentine.
In math when someone says the math is a bit advanced and best left until later often it refers to this mathematical maturity thing - it quite possibly means while you may know the necessary math to understand it, ploughing through it is hard going and is best left until you have more experience with proofs of that complexity.
Thanks
Bill
  • · Replies 31 ·
  • · Replies 24 ·
  • · Replies 60 ·
9K
  • · Replies 16 ·
