Question About The Role of Observation in Quantum Mechanics
The discussion revolves around the role of observation in quantum mechanics, particularly in the context of the double-slit experiment. Participants explore how the presence of a detector influences the behavior of particles, leading to different output patterns, and question the implications of observation on the nature of quantum particles.
  • Some participants note that the presence of a detector before the slits alters the resulting pattern from an interference pattern to a two-strip pattern, raising questions about the nature of observation.
  • There is a discussion about what constitutes "observation" in quantum mechanics, with some suggesting it may involve modifying quantum mechanics to account for gravitational effects on wave function collapse.
  • One participant argues that observation is an interaction that causes changes, but emphasizes that not all observations affect the state of the observed object in the same way.
  • Concerns are raised about the effects of sensors on quantum particles, questioning whether it is possible to mitigate these effects.
  • Another participant describes the electron's impact as being randomly distributed until a large number of impacts create a continuous aspect, relating this to the interference pattern.
  • Some participants clarify that when electrons are detected, they do not merely act like particles; each electron still creates a dot on the screen regardless of detection, but the detection alters the interference pattern.
  • There is a suggestion to watch a Feynman lecture for further insights, with participants outlining different scenarios of the double-slit experiment to illustrate their points.
Participants express various viewpoints on the nature of observation and its effects on quantum particles, indicating that multiple competing views remain. The discussion does not reach a consensus on the implications of observation in quantum mechanics.
Participants acknowledge that the definitions and assumptions surrounding "observation" in quantum mechanics are not universally agreed upon, and there are unresolved questions regarding the interaction between detectors and quantum particles.
  • #31
atyy said:
Feynman was wrong on this point. It is conceptually possible that the electron went through either A or B. https://en.wikipedia.org/wiki/De_Broglie–Bohm_theory
Okay, but Bohmian mechanics generally undermines most of what can be said about orthodox QM.
And, invoking Bohmian mechanics hardly helps someone understand the basics of QM.
  • #32
atyy said:
In quantum mechanics, we cannot get information about a system without disturbing it.
https://arxiv.org/abs/0706.3526
The below reference could be considered a counter-example to your reference. Interference is made to disappear without detection (and without any discernible disturbance, other than change of context). And even if (which slit) information were to be obtained, the act of detection is not responsible for the change in outcomes. I would challenge the idea that the system was "disturbed" as part of obtaining information. Only the relative orientation of the polarizers changes - nothing else.
http://sciencedemonstrations.fas.ha...-demonstrations/files/single_photon_paper.pdf
  • #33
I now understand how and why observation in quantum mechanics is handled differently than in everyday life, or classical Newtonian physics. Thanks everyone for your responses.
  • #34
No it does not challenge it. The author means it in a precise sense, and gives it as Theorem 2.
  • #35
I don't think Bohmian mechanics undermines most of what can be said about orthodox QM. I agree it is not helpful to invoke BM, but unfortunately, Feynman brought up the topic and made an error. I think it undermines orthodox QM, if errors about orthodox QM are left uncorrected.
  • #36
A. Neumaier said:
Yes, see nondemolition measurements. But this doesn't apply for the double slit.
The pattern changes since a detector at the slit has a serious impact on the microscopic stuff going through the slit:
The change in an observed object due to an observation is large if the means of observing it is comparable (or larger) in size and impact to the observed object. If you magnify the situation sufficiently strongly, it is qualitatively like (though not really like) observing a sand castle by a big wave from the shore.
Thanks, this makes a lot more sense. A lot of YouTube videos make it seem like there is some sort of magical thing that happens - "the particle is aware that it is being detected and therefore behaves differently". As though the particle has some sort of consciousnesses and the change isn't just a result of cause and effect relationship between the measurement device and the quantum particle.
  • #37
Indeed, that's true, as my discussion in #18 showed. You don't need to put additional detector in front of one or both slits to gain which-way information. It's also sufficient to place your detector, i.e., the screen where the particles are registered close enough to the slits to be sure through which slit each particle came, but then you cannot observe the interference pattern as detailed in this posting too.
On the other hand, also the gain of which-information through detection at the slit generally destroy the interference pattern. How to explain this depends on the specific way of the detection.
One simple example is to use quarter-wave plates, oriented in a 90-degree angle relative to each other in the double-slit experiment with polarized photons. If you start with photons polarized at an angle of ##0^{\circ}## in the plane perpendicular to their momentum (which is parallel to the plane of the slits) and orient one quarter-wave plate in one slit at ##45^{\circ}## and the one in the other slit at ##-45^{\circ}## you mark the photons themselves such that you can gain which-way information at any distance from the slit, because the any photon coming through slit 1 is left-circular polarized and any photon coming through slit 2 is right-circular polarized and thus the parts of the corresponding electric-field-operators (note that for photons I cannot argue with wave functions as in #18, because photons do not have a position operator nor a well-defined "wave function") annihilate/create photon states that are perpendicular to each other and thus there's no interference term in the detection probability for these photons at a CCD cam placed no matter how far away from the slits and thus no (two-slit) interference pattern.
Now you gained which-way information with 100% certainty and have no interference pattern. If there were no quarter-wave plates you'd get an interference pattern but are left with no which-way information whatsoever. Of course the difference in the two settings are thus these quarter-wave plates and here of course the reason for the disappearance of the interference pattern is the placement of these quarter-wave plates in the slits and the interaction of the photons (i.e., the em. field) with them, leading to the change of the polarization from linearly polarized to either left- and right-circular polarization depending through which slit the photons came. This very setup has entangled the photon momentum with its polarization in such a way that the state of a photon behind the slits allows with 100% certainty to know through which slit it came.
You can in such a setup also choose to know only "somewhat" through which slit each photon came, i.e., you just orient the quarter-wave plates not with ##90^{\circ}## relative orientation to each other. Depending on which angles of the plates you choose, the probability for a photon with a certain polarization state behind the screen is larger to have come through one slit than the other (say 70% through slit 1 and 30% through slit 2). Then it's more likely that the photon came through slit 1 (70% probability) but you cannot be very certain about it because there's still a 30% chance of having come throuh slit 2. In this case you get in turn some interference pattern back, but not of as high a contrast as the one without the quarter-wave plates in the slits. You can also choose, not to get any which-way information with quarter-wave plates at the slits. Then you simply have to orient them in the same direction. Then there's 50% change for the photon to have come from either slit and that's the most uncertain state concerning which-way information the photons can be prepared in. Then you get the two-slit interference pattern with full contrast.
Indeed, as you see you don't need to really detect the photons to gain the which-way information, but an addition like the quarter-wave plates can lead to "imprinting" this information into the photons themselves, but that's so because of the interaction of the photons with the quarter-wave plates.
So there's some objective reason whether there's which-way information, no which-way information, or some uncertain information, which excludes and interference pattern, leads to an interference pattern of maximal possible contrast, or leads to an interference pattern with less contrast in these three cases, respectively.
However according to the laws of QT you cannot have both, i.e., certain which-way information and an interference pattern. These are mutually exclusive possibilities to prepare the photons.
What's also very clear with these examples is that there's no such thing as "wave-particle duality" or any other "weird things" attributed to QT as soon as you accept, as a fundamental law of nature that cannot be explained by any simpler laws, that there's some "irreducible randomness" in nature, which however is precisely described by modern quantum mechanics or, as here for photons, relativistic quantum field theory.
As @DrChinese said above, physics does not explain "why" nature behaves the way she does, she just accurately describes "how" nature behaves. Sometimes you can explain "why" some phenomenon is observed as it is by using theory to "explain" it by calculations according to the fundamental laws described by this theory, but there's no "deepter explanation" of the "why" of these fundamental laws.
Despite some criticism in this forum, I consider the introduction to (non-relativistic!) QM in the Feynman Lectures as among the best there are in the textbook literature. That's because Feynman is a role model for me in explaning QT as it is without any ado with strange philosophical ideas about some apparent paradoxes (there are none within the minimal statistical interpretation). He just sticks to the physics facts and leaves it at this: The probabilistic nature (i.e., Born's rule to intepret the wave function or more generally any quantum state) is just a fact of nature, deduced in about 120 years of experience with quantum theory (or 94 years if you count only the modern quantum theory, which is the one still up to date with today's knowledge).
  • · Replies 28 ·
  • · Replies 36 ·
9K
