Why does time dilation affect all clocks equally?
The discussion centers on the phenomenon of time dilation as described by Einstein's theory of special relativity, specifically addressing why time dilation affects all types of clocks equally, including light clocks and bouncing ball clocks. Participants argue that while light clocks are easier to analyze due to the constancy of the speed of light, the same time dilation factor applies universally across different clock types when properly analyzed using relativistic principles. The conversation highlights the importance of understanding Lorentz transformations and relativistic velocity addition to resolve apparent discrepancies in time measurement between moving observers.
  • Understanding of Einstein's theory of special relativity
  • Familiarity with Lorentz transformations
  • Knowledge of relativistic velocity addition
  • Basic principles of time dilation and its mathematical implications
  • Study the derivation of Lorentz transformations in special relativity
  • Learn about the mathematical formulation of time dilation
  • Explore the concept of relativistic velocity addition in detail
  • Analyze different types of clocks and their behavior under relativistic conditions
Students of physics, educators teaching special relativity, and anyone interested in the implications of time dilation in high-speed travel scenarios.
  • #31
"How exactly would John use his ship as a clock? Withthe light and ball, he measures how long it takes for them to travel a fixed distance in the Y direction relative to him, but the ship has no relative motion with respect to John. "
I meant that Alex could use John's ship as a clock. My main question, though, relates to what we've been discussing about only needing to use the vertical speed to calculate time dilation when the clock is perpendicular to the ship. Many sites on the net that introduce special relativity use the light clock example and explain time dilation by saying that the stationary frame sees the moving frame's time go slower because the stationary frame sees the beam of light going up a longer path. Based on what we've been discussing, the longer path has nothing to do with why the stationary observer sees the clock on the ship tick slower. The lengrh of the path (which is the height of the light clock) is the same for both, it's just that for the stationary observer the light goes up that path slower. True, the stationary observer also views the beam going in a sideways direction, but we only use the length of its vertical path to calculate time dilation. Am I correct about this?
PAllen thank you for that resource. I have not heard of aberration before and will read about it.
  • #32
No, the length of the path taken by the light beam is not the same. In one frame, the light travels just vertically; in the other frame, the light travels diagonally over a longer path.
That's just a calculational convenience. Note that when you do that you only use the vertical component of the velocity.
  • #33
But is it true that the longer path in these examples is not a factor in the time dilation?
  • #34
No, that's not true. That longer path allows you to immediately deduce time dilation (for a light clock).
  • #35
The longer the voyage is that the ship goes on, the longer the diagonal path will be. But the length of the journey is not affecting gamma, only the speed of the ship is?
  • #36
The speed of the ship determines both gamma and the length of the diagonal path. (They are all connected.)
  • · Replies 58 ·
  • · Replies 27 ·
  • · Replies 88 ·
  • · Replies 16 ·
  • · Replies 54 ·
  • · Replies 46 ·
