Question of the basic properties of tan
  • Thread starter Thread starter thunderjolt
    Properties Tan
The discussion centers on solving for angles gamma (γ) and chi (χ) using trigonometric identities involving the tangent and sine functions. The user calculates γ as -16.5° but notes a discrepancy with the expected answer of 73.5°, suggesting a misunderstanding of tangent properties. The key equations used are tan(2γ) = tan(2ψ)cos(δ) and sin(2χ) = sin(2ψ)sin(δ), with ψ defined as arctan(3) = 71.57°. The user realizes that the periodic nature of the tangent function may provide additional solutions.
  • Understanding of trigonometric identities, specifically tangent and sine functions.
  • Familiarity with inverse trigonometric functions, particularly arctan.
  • Knowledge of angle properties in trigonometry, including periodicity.
  • Basic skills in solving equations involving angles and trigonometric functions.
  • Study the properties of the tangent function, including its periodicity and how it affects angle solutions.
  • Learn how to apply the double angle formulas for sine and tangent in trigonometric problems.
  • Explore the concept of angle sum and difference identities in trigonometry.
  • Practice solving trigonometric equations with multiple solutions, focusing on the unit circle.
Students in engineering or mathematics, particularly those tackling trigonometric problems in physics or engineering contexts, will benefit from this discussion.
thunderjolt
I've solved a problem in my engineering homework to a point where I have the following data:
ψ = arctan(3) = 71.57 (degrees) , inverse tangent of 3
δ = 30 degrees
solve for gamma and chi (χ):
tan(2gamma) = tan(2ψ)cos(δ)
My problem rests with the gamma solution. When I draw it (using other data in the problem), it is an angle larger than 70 degrees at least. When I solve for gamma with a calculator I get gamma = -16.5°.
my process:
tan(2ψ) = -.75
(-.75)cos(30) = -0.6495
arctan(-0.6495) = -33°
gamma = -33/2 = -16.5°
I know that there are properties of tangent that you need to take into consideration, but I just cannot remember them, and I am sure that is why I get this negative angle.
Or, did I do this correctly, and I just need to redraw my problem?
EDIT: the answer in the back of the book is gamma = 73.5 degrees
Without knowing the context of the problem, it's hard to say what's going on, but I don't think it's a coincidence that 73.5+16.5 = 90.
I, too, noticed that they summed to 90. Well, the entire problem, minus the EE info, is:
I have an equation that makes an elipse:
E = x[10cos(wt + 30°)] + y[30cos(wt)]
We can make wt our variable. x and y are the vector directions, I believe. (they have hats ^ above them)
gamma is the angle that the major axis of the elipse makes with the x-axis. When I draw the elipse, I can clearly see that said gamma is near positive 70°)
ψ is the angle that the amplitudes of the x and y components make with the x-axis (arctan(30/10) = 71.57)
and chi, χ, is an angle that is hard to describe, but not pertinent to what I need help with.
The tangent function has a period of 180°, so when you take the arctan, you can add 180° to what the calculator gives you to get another solution.
  • · Replies 20 ·
