Question on a particular integral property
The integral identity provided in Wald's book on general relativity, F(x)=F(a)+\int_{0}^{1}F'(t(x-a)+a)dt, is valid under specific interpretations of the derivative notation. The discussion clarifies that the formula holds true when F'(t(x-a) + a) is understood as the derivative of the function φ(t) = F(t(x-a) + a) evaluated at t. However, using standard notation where F' denotes the derivative of F at the point t(x-a) + a can lead to inaccuracies. The conversation also emphasizes the importance of the fundamental theorem of calculus in deriving this expression and its application in proving the Taylor series representation of smooth functions.
  • Understanding of integral calculus and the fundamental theorem of calculus.
  • Familiarity with Taylor series and smooth functions.
  • Knowledge of derivative notation and its implications in mathematical expressions.
  • Basic concepts of general relativity as introduced in Wald's book.
  • Study the fundamental theorem of calculus in detail to understand its applications.
  • Learn about Taylor series and their derivation for smooth functions.
  • Explore the nuances of derivative notation in mathematical literature.
  • Read Wald's book on general relativity, focusing on the implications of integral identities in physics.
Mathematicians, physicists, and students studying calculus and general relativity who seek to deepen their understanding of integral properties and their applications in theoretical frameworks.
"Don't panic!"
I've been reading Wald's book on general relativity and in one of the questions at the end of chapter 2 he gives a hint which says to make use the following integral identity (for a smooth function in): F(x)=F(a)+\int_{0}^{1}F'(t(x-a)+a)dt
Is this result true simply because \int_{0}^{1}F'(t(x-a)+a)dt=F(t(x-a)+a)\bigg\vert_{t=0}^{t=1}=F(x)-F(a)
And so F(x)=F(a)+\int_{0}^{1}F'(t(x-a)+a)dt=F(a)+\left(F(x)-F(a)\right)
Or is there a deeper explanation to it?
I get that one can arrive at this expression by starting from the fundamental theorem of calculus and making a change of variables, but I'm unsure of what he's trying to say with it?!
Nothing deeper- that's basically why it is true. As to "what he's trying to say with it", I suspect that depends on what he is try to do.
I should mention sloppy notation here. The formula is true if ##F'(t(x-a) + a)## is understood as derivative of the function ##\phi##, ##\phi(t) = F(t(x-a) + a)## (evaluated at ##t##). However, in the standard notation ##F'(t(x-a) + a)## means the derivative of ##F## evaluated at the point ##t(x-a) + a## , and in this case the formula is false (consider say ##F(x) =x##, ##a=0##).
Likes PeroK
Yes, I admit it is a bit sloppy, I was just copying over the notation that Wald gives it in. I'm assuming he meant F'(t(x-a) +a)=\frac{dF(t(x-a)+a)}{dt}?!
He gives it in a question in which he asks the reader to prove by induction that for any smooth function F : \mathbb{R} ^{n} \rightarrow \mathbb{R} ^{n} one can express it as the following power series (i. e. a Taylor series) F(x) =F(a) +\sum_{i=1}^{\infty}(x^{i}-a^{i})H_{i}(x), where x=(x^{1},\ldots,x^{n}) and a=(a^{1},\ldots,a^{n}), and in particular, \frac{\partial F} {\partial x^{i}} \bigg\vert_{x=a} =H_{i} (a). He gives a hint that for n=1, you should use the "known" identity I gave in my first post. I can do the first step in the induction process, by starting from the fundamental theorem of calculus and making a change of variables, but I'm not entirely sure what this is showing. I'm also unsure how to proceed after making the induction step?!
You just should apply the formula $$\phi(1) = \phi(0) +\int_0^1 \phi'(t) dt$$ (the fundamental theorem of calculus) to $$\phi(t) = F(a+(x-a)t). $$
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 20 ·
  • · Replies 16 ·
