Question on excitation energy?
  • Context: Undergrad
  • Thread starter Thread starter HMS-776
    Energy Excitation
8 replies · 8K views
HMS-776
Just wanted to ask a simple question to clarify my thinking.
The Ionization Energy of an atom is said to be the minimum energy required to bring the electron to it's next higher orbit.
Looking at the Oxygen atom's first ionization energy of 13.6eV. Does this mean that any energy level which is 13.6eV or higher will cause the first ionization to take place?
Does this hold true for wavelength? A wavelength which is shorter than the absorption wavelength will also cause ionization because the shorter wavelength is stronger?
Yea, any energy higher than the required energy will cause the ionization. The higher the energy, the more likely the ionization will take place. Also, the surplus of energy will contribute to the kinetic energy of the electron.
A higher energy automatically means a shorter wavelength, so this also holds for this, yes.
The ionization energy is the minimum energy that will completely remove the electron out of an atomic orbit and produce a free electron and a negative oxygen ion (with 7 electrons). The maximum wavelength is about 904 Angstroms.
There are some misconceptions here, so I'll clear up what I can.
No. The Ionization Energy would completely remove an electron from the atom, as Bob S said.
It is the First Excitation Energy that brings an electron to it's next higher orbital.
That 13.6 eV value is for hydrogen, not oxygen.
This question doesn't really make sense. A photon of 13.6 eV or more energy can cause ionization -- in hydrogen.
Yes, that is true.
From HMS-776
Redbelly98 said:
That 13.6 eV value is for hydrogen, not oxygen..
I stated in another thread by HMS-776 that the ionization energy for one-electron bound states of atoms is
eV = 13.6 Z2/n2.
Oxygen has Z = 8, so the 1S electron binding energy is 870 eV.
Bob S said:
I stated in another thread by HMS-776 that the ionization energy for one-electron bound states of atoms is eV = 13.6 Z2/n2.
?:confused:
I think that the upper electron is as bound to the Oxygen ion O+ as the Hydrogen electron to proton so the Oxygen ionization energy should be of the same order (13 eV or so).
The excitation probability or cross section depends on the projectile energy in a specific way: it is zero before the ionization energy threshold, then it grows with the energy, attains a maximum and then decreases.
Bob_for_short;2345494I think that the upper electron is as bound to the Oxygen ion O[SUP said:
+[/SUP] as the Hydrogen electron to proton so the Oxygen ionization energy should be of the same order (13 eV or so).
QUOTE]
Thanks, short Bob. You are right, as usual. See Table of ionization energies (comma = period):
http://www.lenntech.com/Periodic-chart-elements/ionization-energy.htm
Long Bob
