Question on Variation of Parameters
yungman
I have a question on the integration part of the Variation of Parameters. Given .[tex]y''+P(x)y'+Q(x)y=f(x)[/tex]
The associate homogeneous solution .[tex]y_c=c_1y_1 + c_2y_2[/tex].
The particular solution .[tex]y_p=u_1y_1 + c_2y_2[/tex].
[tex]u'_1 = -\frac{W_1}{W} = -\frac{y_2f(x)}{W}[/tex]
This is where I have question. Some books use indefinite integral with the integration constant equal 0.
[tex]u_1= -\int \frac{y_2f(x)}{W}dx[/tex]
But other books gave:
[tex]u_1= -\int_{x_0}^x \frac{y_2f(s)}{W}ds[/tex]
Where [tex]x_0[/tex] is any number in I.
None of the books explain this. Can anyone explain to me about this?
Thanks
If yp = u1y1 + u2y2 is a particular solution you found, then compare this to:
Yp = (u1+A)y1 + (u2+B)y2
=u1y1 + u2y2 + Ay1+ By2
When you plug the second expression into the equation the last two terms give 0 because they satisfy the homogeneous equation. So the constants don't give anything extra.
Thanks for the respond.
So you mean even using definite integral, substituding in x0 only produce a constant as in your example of A and B. These will be absorbed into the associate homogeneous part ( into c1 and c2).
Thanks
Does it matter? We only want a particular solution.
