What is the mass of NH3 per cc in a solution of ammonia gas passed into water?
The mass of NH3 per cc in a solution of ammonia gas passed into water is calculated using the solution's density of 0.93 g/cm³ and a weight percentage of 18.6% NH3. The correct mass of NH3 per cc is 0.17 g. The initial approach using the molarity equation was incorrect, as the equation provided was not universally applicable and led to confusion. A more straightforward method is required to solve for the mass of NH3 without overcomplicating the problem.
  • Understanding of density and weight percentage calculations
  • Basic knowledge of molarity and its application
  • Familiarity with the concept of moles in chemistry
  • Ability to perform unit conversions between grams and milliliters
  • Review the correct application of molarity in solution calculations
  • Study the relationship between density, mass, and volume in solutions
  • Learn about the significance of weight percentage in chemical solutions
  • Explore the concept of moles and their calculations in chemistry
Chemistry students, educators, and anyone involved in solution preparation and analysis, particularly those focusing on ammonia solutions and related calculations.
Prashasti
Ammonia gas is passed into water, yielding a solution of density 0.93 g/cm^3 and containing 18.6% NH3 by weight. The mass of NH3 per cc of the solution is
1) 0.17
2) 0.51
3) 0.34
4) 0.68I solved it using the molarity equation.
Molarity = 10xd/MM
where,
x - % by weight
d - density
MM - Molar mass
And then I multiplied molarity with Molar mass (17 g mol^-1) and got 172.98 as the answer, whereas the answer is 0.17.
Where did I go wrong?
Prashasti said:
Molarity = 10xd/MM
Here.
First, this equation is wrong as written, second, even in the correct form it is not universal - it works only in specific situations. Do you know what they are?
No. I'm in high school. So, I don't know much about that. What specific situations are you talking about? .
Borek said:
Here.
You were given this equation without any explanation?
Let ##x,y## the number of moles in a cc. Writing the problem we have:
$$ \frac{17x}{17x+18y} = 0.186\times 0.93 $$
Perfect way of overcomplicating things. How you are going to solve one equation with two unknowns?
Forget about molarity which doesn't enter into his simple arithmetical problem.
Even forget about the density - it's not a million miles away from 1 g/cc.
Then only one of the given answers is anywhere near anything you would expect.
Though once you have seen which it is, do the working out of the exact answer.
HINT:
MOLARITY is the number of moler PER LITRE of solution. Whereas you are asked the mass of NH3 in millilitres (or cc).
11K
