Questions about centripetal force
The discussion revolves around centripetal force experienced by riders in the Gravitron amusement ride. The force exerting centripetal acceleration on the riders is identified as the normal force from the wall, not gravity, which acts downward. The vertical forces on the riders must balance, meaning the normal force equals the gravitational force for them to remain suspended. The force of friction between the riders and the wall is crucial for preventing them from falling. Calculations for the minimum frequency of rotation required to keep the riders safely against the wall involve using the relationship between friction, normal force, and centripetal force, ultimately leading to a frequency of approximately 0.30 Hz or its equivalent in rpm.
sheenu32
1. Mr. B takes his grade 12 physics class to the local amusement park at Hopedale Mall to conduct some experiments on friction and centripetal force in the gravitron. The Gravitron is an amusement park ride shaped like a vertical cylinder with a radius of 7m. Riders stand with tier backs against the inside wall of the cylinder, facing the center. As the cylinder begins to rotate faster and faster, the riders become pinned to the wall. The floor then dissapears and the riders are left suspended against the wall as the ride continues to rotate at top speed.
a) what must be exerting force on the riders to give them the necessary centripetal force directed towards the center of the cylinder? what type of force is this?
b) What must be true about the vertical forces on the riders, given that they are moving in a horizontal circle?
c) what force is holding the riders up against gravity so that they do not fall?
d) Given the coeffience of friction between a typical rider and the wall is aprroximately 0.4, what is the minimum freequency of rotation required so that the riders do not fall? Express yur answer in rpm.
for part d i think we use this equation
Fc= mass*4*radius^2*freequency^2
a) i think the answer for this is the gravity of the Earth that's exerting force. This is Fg force which is equal to Fn
b) they should b equal to each other positive
c) Ff
d) i didnn know how to solve this at all
Plz try to help me i m kinda stuck i get the idea but i donnohow to explain it
Gravity acts downwards, so how can it possibly be directed towards the center of the circle of motion as a centripetal force?
oh so the force that's towards the centre is the force of friction?
No. Frictional force acts in the opposite direction to the gravitational force.
And the normal force is provided by the centrifugal force due to rotation of the cylinder.
Alright what's up sheenu32, i have feeling i am your class, so let me attempt question for you.
a) I believe you are right about the normal force, but the normal is not the force of gravity, it is the force exerted by wall on the passenger.
b)they cancel out
c)the force of friction of the wall
d) well this is how i attempted it:
Ff=Fn*.4
Fn=Ff/.4
Fn=Fc
Ff=mg(opposite force of gravity)
mg/.4=m4pi^2rf^2
m cancel
g/.4=4*pi^2(7)f^2
24.5=4*pi^2(7)f^2
f=.30 Hz
convert .30 Hz to rpm
and tada you get your answer
I think that's right lol
someone correct me if they see something wrong
PLEASE WE HAVE BIG TEST ON MONDAY!
b)they cancel out
Ff=Fn*.4
Fn=Ff/.4
Fn=Fc
mg/.4=m4pi^2rf^2
m cancel
g/.4=4*pi^2(7)f^2
24.5=4*pi^2(7)f^2
f=.30 Hz
ooo thnx but we need to give more explanations for it though
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
