Quick Analysis Problem - Related to properties of cont functions
3 replies · 1K views
brickcitie
Quick Analysis Problem -- Related to properties of cont functions
This problem assumes that f: R ----> R is continuous on all of R. I need to determine if the following set is guaranteed to be closed, regardless of f(x).
A = {x in R | 0 <= f(x) <= 1}
Everything is contained above.
Ok so I have tried for a while to come up with a counter example. My first idea was to let f(x) = 1/ x^2 + 1, but then A = R which is closed and doesn't help my case. My next idea was to let f(x) = sinx, but then A is an infinite union of closed intervals on R, which I believe is a closed set.
I cannot think of any counter-example, so I'm guessing A will be guaranteed to be closed, but I cannot really get a formal proof started. Any idea?
Take [tex]f(x)=x[/tex]. Then A is not open...
Also note that an infinite union of closed sets is not necessairly closed. You mentioned that, but it is incorrect.
Hi again micromass. So I mis-typed this originally; I meant to say that I need to decide whether it is guaranteed to be closed. The first part of the question was whether it was open or not, and I used the same function you just mentioned to answer that.
And also, won't any infinite union of closed disjoint intervals in R be closed, because the complement will be an infinite union of open intervals, and thus open?
Oh, I see.
Well do you know that a function is continuous if and only if for every open set G holds that [tex]f^{-1}(G)[/tex] is open??
As for the second part. The complement of an infinite union of closed sets is an infinite intersection of open sets, and this is not guaranteed to be open.
But if you take the infinite union of DISJOINT closed sets, then it is indeed closed. But not for the reason you stated...
