Quickest way to do this calculation
15 replies · 3K views · last reply
Manasan3010
Find value of ##x##
## \frac{-3x^4}{7}+x=\frac{-3x^4}{7}+10 \\x=10##
I solved the equation and got x=10, My question is how can I solve for x without brute-force method( Multiply all terms by (x-13)(x-7)(x-14)(x-6) and solving for x)
\begin{align*}
\dfrac{5x-64}{x-13}+\dfrac{x-6}{x-7}&=\dfrac{4x-55}{x-14}+\dfrac{2x-11}{x-6}\\
\dfrac{5(x-13)+1}{x-13}+\dfrac{x-7+1}{x-7}&=\dfrac{4(x-14)+1}{x-14}+\dfrac{2(x-6)+1}{x-6}\\
5 + \dfrac{1}{x-13} + 1 + \dfrac{1}{x-7}&=4+\dfrac{1}{x-14}+2+\dfrac{1}{x-6}\\
\dfrac{1}{x-13} + \dfrac{1}{x-7}&=\dfrac{1}{x-14}+\dfrac{1}{x-6}\\
&\text{ etc. }
\end{align*}
looks a lot easier!
Continuing with:
\dfrac{1}{x-13} + \dfrac{1}{x-7}=\dfrac{1}{x-14}+\dfrac{1}{x-6}
From there ...
##\dfrac{x-7 + x-13}{(x-13)(x-7)}=\dfrac{x-6 + x-14}{(x-14)(x-6)}##
Some simplifying gives
##\dfrac{2(x-10)}{(x-13)(x-7)}=\dfrac{2(x-10)}{(x-14)(x-6)}##
Equate the denominators & solve for ##x##.
From
\dfrac{2(x-10)}{p(x)}=\dfrac{2(x-10)}{q(x)} \quad (p\neq q \in \mathbb{R}[x])
is nothing left to solve, it is already written there.
fresh_42 said:
From
Can you please elaborate on how the numerators of the fractions are being equalled.
Even if the numerators are equal, equation would become
2x-10 = 2x-10
x=x(How do I find the value of x from this)
I also want to know what is meant by## \quad (p\neq q \in \mathbb{R}[x]) ## in words.
That equation simplifies to 91 = 84 so (1) clearly you've made a mistake somewhere, and (2) it can't be used to find x since the x's all drop out and just leave 91 = 84. Not very useful.
##\dfrac{2(x-10)}{(x-13)(x-7)}=\dfrac{2(x-10)}{(x-14)(x-6)} ##
Following @fresh 42's hint, if x=10 both sides of the equation are zero, independently of the denominators. They need not be equal. So the solution is x=10
But How do I mathematically show that 10 is a possible solution for x?
In test can I say that If you plug 10 for x, Equation is veracious so 10 is a possible solution?
And, as per fresh's post #5, there are no others.
Alternatively, rewrite the last expression in post #3 as$$\frac 1{x-7}-\frac 1{x-6}=\frac 1{x-14}-\frac 1{x-13}$$and put each side over a common denominator. The result is one over a quadratic in both cases, and the result follows simply.
##\dfrac{a(x)}{p(x)}=\dfrac{a(x)}{q(x)} \Longleftrightarrow a(x)(q(x)-q(x))=0 \Longleftrightarrow a(x)=0 \text{ or }p(x)=q(x)##
As we can rule out ##p=q## we are left with ##a(x)=2(x-10)=0## and it can be seen that ##x=10## is the only way for ##a(x)## to be zero.
So all steps which are missing in post #3 can actually be done in mind.
I have a bad habit of writing up a post, previewing and editing until most typos are fixed, then when it's ready to go, I neglect clicking to post it. :headbang:
The following is part of a post I wrote up yesterday evening, shortly after @phinds (that big white dog could pass for a polar bear) posted that enlightening observation.
Oh my! Yes, of course.
... And since you point out that the denominator on the left is 7 units greater than the denominator on the right (for all values of ##x##), the only solution possible is for the numerators to be zero.
Good point. That's a point of view I've never had to take before so basically rejected it. Not too bright sometimes, but I mean, come on ... I'm just a dog after all :smile:
fresh_42 said:
From
2x-10 = 2x-10
@Manasan3010, did you mean "even if the denominators are equal..."
If so, the numerators are ##2(x - 10) = 2x - 20 \ne 2x - 10##
Yes. After all those manipulations of equations, it is always good to show that your answer satisfies the original equations. Then you should ask yourself if there are additional solutions. If x is not 10 and the numerators in the last equation of post #4 are equal but not zero, then the denominators must be equal for some value of x other than 10. But @phinds pointed out in post #7 that setting the denominators equal leads to 91=84, so that is not possible.
